Location: Central Coast CA, South Eastern WA, Bay Area CA and MAUI Hawaii
6 Foot Driver in a 914
I'm thinking about getting my son a 914 he is 6'1
any tall 914 guys chime in
86 930 turbo perfect 89 911 targa will be someday 95 surburban 180k and still love it 87 300d mercedes airport car Living Life Is...... Choices and Chances Make Some and Take Some |
I'm 6'3" and bought mine when I was 20 years old. Still have it. No problems.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
gearhead
6'3" no problems. In fact more comfortable than my 911
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I'm 6' 5". Not enough head room but there's enough leg room.
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928 Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944 |
I'm 6'4" and 275 lbs and have no problems
it's a little close between the shift stick and the steering wheel, but not a problem |
you only need two feet to drive a stock 914, the four other feet are useless. If you got one foot, consider an automatic transmission car.
914 Geek
I am 6'1", but have a long waist. I have headroom problems in many cars. The 914 is better than most, though a bit marginal for me with the stock seat. My head will brush the headliner when the roof is on the car.
If I remove the bottom seat cushion, or replace it with a thin foam pad, I have no problems. Even with a helmet on. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
thanks guys
may have another car in stable soon
I'm 6'6" and 275lbs and my brother is 6'4" 200"lbs and we both fit in the car. We were shocked we both fit when I was test driving the car before I bought it.
The shifting could be tricky where it hits your leg for first gear but you can get a short shift or cut the shifter length down and it is not an issue. Mine was missing a base cushion, which are pretty thick, so when I had mine made I used better foam and had a thinner one made. This can get you an inch or two. |
