Lawrence914's Avatar
914-6 Throttle Linkage Adjustments
Is there a tech article or directions anywhere for proper adjustment of the 914/6 throttle linkage?
I've gone through the factory workshop manuals, and can't find step-by-step directions.
TIA,
Lawrence
Old 09-22-2002, 03:05 PM
Well.......I have an OEM set-up and it works.......didja want pics or whut? I got some, I think.....Yup, here's a couple and another
These will give an idea of orientation. Adjustment is a bit tougher.
I can take some more pics going futher up the line if you have the need.
JPIII
Early Boxster
Old 09-22-2002, 04:04 PM
Hiya JP!
Thanks for the pictures. That looks really clean.
I've got the linkage in place. It works, but I think that I may have some free HP in there. When I reassembled the car (back in 2000), I just bolted it all together. No adjustments, really.
I'd like to do it right before the Mid US Ramble this year.
-Lawrence
Old 09-22-2002, 04:07 PM
canna change law physics
red-beard's Avatar
I just take all of the slack out of the cable with the adjusting nuts. If you can't, you need to look at taking slack out of the rods, then adjusting the cables.
Or the cable has stretched and is about to fail...
James
James
Red-beard for President, 2020
Old 09-22-2002, 04:10 PM
Mike Ginter
gint's Avatar
Hey JP, I see a little dirt and grease in those pics...
Ginter's 914 stuff
Old 09-22-2002, 04:14 PM
You'll note that the bell crank (second pic) is level and the pivot at the trans is nearly so.
then, the crossbar attach arm is close to plumb. This will allow
full opening of the carbs. The linkage to the carb on the pass side
is set to make up the space when these other thingies are orientated properly. The drivers side down link is set when syncronizing the carbs, side to side......the tricky part.
HTH
Dirt.....grease? where?.....auggh!
Humm....looks like the date goodie on my camera is off a bit.
I'd fix it iff'n I knew how.....whut size wrench do I use?
JPIII
Early Boxster
Old 09-22-2002, 04:27 PM
914 Geek
Lawrence, drop Rich Johnson a yell about the linkage. He has repop'ed the original setup, and knows a thing or two about adjustments... If nothing else, you can ask him in person at the MUSR if you don't get it done by then!!
--DD
Old 09-23-2002, 08:48 AM
