Facet pump not pumping fuel
Cant seem to get the facet pump (new unit) to pump. Makes noise but doesn pump. Its under my gas tank. m
Also the power to the pump is not working either. Currently, I've been hooking up a 12 volt source to make it work. Are there any additional wiring tricks I need? |
914 Geek
If it's making noise, there is power getting to it.
Two things come to mind: - Do you have the power and ground wires on the correct terminals? Could they be swapped? - Do you have the inlet and outlet hoses on the right fittings? Could they be swapped? --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
