porschetub's Avatar
914/6 oil filter console
Can someone school me up on the filter console for the 914/6 oil tank ,I have a bad 75 model 911 tank which is cr#p but the console is great ....has no part number that I can find on the casting.
Any chance this will fit the 914 tank ? research indicates it should but not 100% sure,help would be great thanks.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 10-28-2014, 12:17 AM
Emo993's Avatar
914-4's do not have a oil tank. Oil in the sump...Mark
Old 10-28-2014, 02:59 AM
If it's a removable console, it fits. 1975 USA version had the filter screwing right into the tank, so it isn't an appropriate donor. BE SURE to use a new o-ring (999 701 100 50). You'll need the later oil filter, too (930 107 764 01).
The Cap'n
Old 10-28-2014, 07:54 AM
porschetub's Avatar
read post again ,cheers
Old 10-28-2014, 06:50 PM
porschetub's Avatar
The Cap'n
Thank you ,wise words as always,I have the right one in this case.
Old 10-28-2014, 06:53 PM
Emo993's Avatar
Yup, makes more sense now.....mark
Old 10-29-2014, 08:58 AM
porschetub's Avatar
The Cap'n
So this oil filter is classed as an upgrade or improved design ?,just asking before I order,do you have the Mahle number by any chance?,thanks
Old 11-16-2014, 09:54 AM
The '72 and later cars use a filter with a larger inlet, and the threaded stub is larger to match. You can't put the late filter on the early console, and you can't put the early filter on the later console (or tank, if there's no console). It's NOT an "upgrade" per se, it's just different. The part number for the later filter is 930 107 764 01. The Mann number is W940/29 and Mahle is OC 54. Avoid all other brands.
The Cap'n
Old 11-16-2014, 01:33 PM
