Anybody make Adjustable Drop Links?
Picked up a stock sway bar at Pomona last weekend and installed it this weekend on the white car.
When I went to look for the U-tab connections, to my surprise only one side had the tab.... then I recalled... oh yeah... this car had been hit... on the hit side there was U-tab, on the original side, there was none.... my mistake... had to genearate up an extra U-tab along with the mounting plates for the bushing mounts. I ended up putting a bolt through on one position of the mounting plate to form a "stud"... makes assembly a little easier.
There was a slight pre-load on the bar when I put it all together with the wheels off and the car jacked up.... not sure how to tell if there is a residual preload once the wheels are back on and the car is down... I guess try to unbolt things and rebolt with wheel on?.... Seems to me, without some time on a skid pad these things would be hard to tweek to optimum for real world conditions.
I would like to build some adjustable drop links or modify the existing ones.... any of you guys done it?... too cheap at least right now to fork over $100+ for some commercial units...
- Dave
Old 10-21-2002, 01:34 PM
HMeeder's Avatar
Porsche Crest Weltmeister Makes Them
Pricey too.
I saw them for around $140.
Herb
'72 Tangerine 'Teen
2.4 liter aluminum handgrenade
Old 10-21-2002, 05:37 PM
chrisreale's Avatar
If I spring the $300 for a 19mm sway bar, does it come with adjustable drop links?
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 10-21-2002, 07:43 PM
Stay away from my Member
campbellcj's Avatar
They come with a one-way adjustable link, i.e. a threaded turnbuckle on one end only.
The ones sold separately (for the big $) are adjustable on both ends and are designed so you can fine-tune them while still connected on the car. With the normal one-way kind, you have to disconnect the drop-link from the A-arm to adjust the preload.
In my view, that's not a big deal, because once you install the bar and set the preload, it really shouldn't change often at all.
The other nice thing about the fancy drop links though, compared to stockers, is they have no rubber in them. That by itself makes a noticable difference in the effectivity of the swaybar.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 10-21-2002, 08:16 PM
HMeeder's Avatar
Porsche Crest Where's my dictionary?
is 'effectivity' a real word?
Herb
'72 Tangerine 'Teen
Old 10-21-2002, 09:33 PM
chrisreale's Avatar
I think the proper word would be effectiveness, but I understiznud what he was sizayin'...yo
www.914club.com
Old 10-21-2002, 09:55 PM
campbellcj's Avatar
Sorry, had work on the brain -- yep, effectivity is a real word
http://www.dictionary.com/search?q=effectivity
Chris C.
Old 10-21-2002, 10:17 PM
