Looking for 914-6 rear calipers!
Probably not going to find any. But perhaps someone has or makes spacers so I can widen my 914 calipers so I can use 911 vented rotors. I have 914-6 hubs and stubs. I want to keep the parking brake. Any help would be greatly appreciated!
Thanks!
Old 02-27-2015, 08:56 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
contact Eric Shea at pmbperformance in UT
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 02-28-2015, 05:00 AM
David McLaughlin's Avatar
I seem to remember reading that a Ferrari 308 rear caliper was the same, more affordable and more plentiful.
1970 914/6 RustoMod
2015 Mercedes E400
Old 02-28-2015, 05:39 AM
I've heard about using the 308 calipers but I've been watching ebay for a while but no luck so far. Is there a better place to look for the 308s ?
Thanks for your reply!
I've checked the pmb website and their sold out of 914-6 and 308 calipers��
Old 02-28-2015, 05:46 AM
914 Geek
The only difference between the 914-4 and 914-6 calipers is that the latter have a larger-diameter piston. They are both made for non-ventilated brake rotors.
I believe that Eric at PMB has the spacers made to put in the middle of the 914 rear calipers for use over ventilated rotors. Contact him about converting yours, or buying a set that have been converted already.
Oh--and on the subject of 308 calipers, the Ferrari guys used to hunt down 914-6 rear calipers as inexpensive alternatives to theirs. The F-badge carries a bigger premium than the P-badge ever did...
--DD
Old 02-28-2015, 09:18 AM
The 9 Store
I have a pair of 914-6 GT calipers. Restored by PMB/eric shea. Will fit vented 911 rotors. $2K + shipping and PP fees. PM me if interested. Thanks, mark
Old 02-28-2015, 07:36 PM
Hell Belcho
Nostril Cheese's Avatar
You can shim the stock rear calipers without splitting to fit non vented rotors. Unless you are racing, I cant think of any reason why you'd need vented ones.
Old 03-01-2015, 03:40 AM
914-6 Brakes
If memory is correct, use of a 911 vented rear rotor will require the rotor diameter to be reduced in addition use of a spacer for the caliper. I have included some photos of 914-6 GT rotors and calipers for reference (coupled with early aluminum S brakes/calipers) that are on my 6. I have the necessary machining dimensions somewhere in my reference material, if you need it. Good luck with your search/project
Old 03-01-2015, 10:21 PM
914 Geek
It's easier to move the caliper outward than to turn down the OD of the rotor. Often, the interference is small enough that just loosening the caliper mounting bolts and pushing the caliper outward while tightening them is enough to get you the space you need! Sometimes more is needed, but it usually isn't very much.
--DD
Old 03-02-2015, 08:42 AM
Porsche Doc's Avatar
Thumbs up
I have a set of 914 calipers with the spacers installed for vented 911 rotors.
I'll take $620 w/Shipping
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
Old 03-03-2015, 08:39 AM
914 Geek
They do look like they could use a rebuild, but that's a pretty safe assumption with any used brake parts.
--DD
Old 03-03-2015, 10:49 AM
Dave... sorry!
No... they where rebuilt a year ago. There are ready to use. Maybe could use a repaint!
Thanks!
Old 03-03-2015, 07:55 PM
djpateman's Avatar
Not really, they are totally different castings. The 914/6 calipers are much larger, and take larger pads than the 914/4. The 914/6 are more similar to the 911 rear calipers with the exception of the parking brake mechanism. Look at the photos above to compare.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 03-04-2015, 04:09 PM
Turboman's Avatar
Send a message via Skype™ to Turboman
I follow Dave's advice, first a talk with Erik at PMB Performance and them start rebuilding.
Erik is the only one that sells complete sets to rebuild 914-6 rear calipers. PMB's video help me a lot. A must.
Take care Francisco
Old 03-05-2015, 08:25 AM
totle's Avatar
Anyone know where to buy the spacers for the rear calipers?
Think PMB does not have these anymore.
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 03-05-2015, 03:11 PM
Turboman's Avatar
Totle, They do. Call PMB.
Old 03-05-2015, 11:37 PM
Thanks to everyone for all your help and advice! I contacted Eric who took the time while he was getting his 914-6 ready for the long drive ahead of him to help me out with my brake setup.
Thanks Eric!!!
Old 03-06-2015, 02:45 PM
Thanks Eric!!!
If Eric doesn't have a pair of 6 rear calipers and you have had no luck yet, please contact me.
I have a set.
Rory rgalla9146@aol.com
Old 03-23-2015, 03:48 PM
PMB Performance
Eric_Shea's Avatar
We should have 3 pair in stock after Hershey.
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 04-27-2015, 12:35 PM
