914-6 Rear Window with Defogger
I want to add to my 914-6 (1970) a rear window with defogger.
I do have the rear window and the correct switch. After a week looking at the manuals and all my related literature, I have not a clear idea "how to wire the defogger" I found on my Factory Manuals that I need to use a relay on my main board. Unfortunately, I only have two relay positions on my main board and both are on use. Some one with a clear easy diagram I can use as a guide? Thanks in advance. Francisco |
It really would'nt be to much hassle to wire one in,as far as I can see it maybe your only option. I have a demist type rear screen and no wiring on it...sucks. Good luck.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Slippery Slope Expert
Question: why bother other than to say you have it? Back in the '70's I lived in Kansas City where (at that time, not so much recently) we had a lot of nasty winter weather. I had a '70 914, and later a '70 914-6 (I had the latter for 18 years) for my daily drivers and because of the sheltered and back-slanting configuration of the rear window I can't ever remember needing the rear window defogger option, nor ever having to scrape the rear window. So there a reason that's a rarely-seen option.
Now if you just want it for brag gin' rights, that's another story. |
.Surely the inside must fog up somewhat @ times...just asking .Personally if you have a car you like isn't it nice to have things working ?,cheers.
Control Group
He is saying you don't need it due to the way the rear window is protected from the elements, both by the sail panels and the rear of the top. I know a guy that will probably know the score
She was the kindest person I ever met |
I never had the idea to generate a debate on this forum.
Searching more carefully thru my Service Manuals, I fund a diagram for 1994 model. My 1970 914-6 have a different relay board, but I feel I can do it. Nevertheless ideas are welcome. Keep all of you posted. Francisco |
No, not that way @ all ,not interestested in starting a pissing contest,but was merely asking why it is not required ...Porsche put it there for a reason,they have never been a company to add useless stuff...mostly.
Funny got home today after some recent bad weather and noticed the inside of mine was fogged up....
My last 914-6 (1970) had a defroster rear window and my '71 will when it finally goes back together. I like the look of the defroster window and it was an option, so it will be installed and working. On my '70 I can count the number of times I used it on one hand, nonetheless, I like them.
'71 914-6 #0372 '17 Macan GTS |
Cairo, If you have the opportunity to look a the loom, please let me know the color of the cables. Thanks
Francisco |
