Would a bad voltage regulator---
permit TOO much voltage? Was thinking my voltage gauge was wonky when it started
reading almost 16v on start up. (Settles down to 14v+ after a minute or 2). Checked voltage at battery not running-- 14.5v and running-- 15v or so So, now wondering if my multi meter's out of calibration. Or, voltage reg. going or n.g. Thanks for any thoughts, p2 |
83 911 Production Cab #10
Yes, BTDT, boiled the battery and luckily I did not fry anything else.
VR will limit the voltage to 14.2 Volts to charge the battery. When they go bad, they can put out up to 17-18 volts which is not good... In your case 14.5 volts at the battery with the engine off is not good, should be in the 12V range. Double check with another Voltmeter and if it remain the same, time for a new VR.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 06-03-2015 at 04:49 PM.. |
Yep its toast,and you will toast your battery also soon,don't go any further till you change it out,13.8 volts is generally the max,cheers
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Thanks guys.
For the help. Got a spare around here somewhere...
p2 |
you can open up the vr and clean the points. just have to pry the cover off
82 SC , 72 914 |
Let that be a lesson to me...
Swapped in another v.r. and everything's back as it should be voltage wise.
Close inspection revealed near new Optima with a small bit of brown ooze exiting the vent things on top of the battery. Reads 13.5v so hopefully I didn't do it much harm. Evidently couple hundred miles at too much voltage= bad for battery. Live & learn---pay for the education. p2 |
