Steve S
Rear shocks
Had the car on a hoist trying to install a stock Dansk muffler. No luck as the previous owner had filled in the dent in the rear valance perfectly (with a lovely welded insert) and the exhaust pipe needs it. So the Ansa one goes back on till I figure what to do next.
I noticed the rear Konis seemed to be hard up against the control arm. The bushes in the lower end of the damper seem worn or distorted. Is this a problem? If so do I need to replace the dampers or are there replacement bushings. Or is a spacer missing? The shocks themselves seem quite firm so I was wondering if there is a simple fix to re establish some clearance.
Old 06-19-2015, 02:35 AM
Some threads just need some images to understand and provide possible solutions.
Possible?
Sherwood
Old 06-20-2015, 10:38 AM
Steve S
Here are some photos. Someone did a really nice job in the past of closing the exhaust cut out.
I would have thought there ought to be a couple of millimetres clearance between the edge of the damper's body and the arm.
Both L & R are the same.
Old 06-20-2015, 07:12 PM
porschetub's Avatar
Bummer about the exhaust cut out?? some people?,the shocks have bad bushes no question,take them off and go to your local suspension shop,you could buy a split poly bush or find a rubber one to push in.....but please check the shock condition before going any further.
By the way you should have one thick washer on the inside ,that will help,it least that is how my car is,cheers.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 06-20-2015, 10:26 PM
Steve S
Thanks. re the one thick washer on the inside That's what I was thinking but I couldn't see one in the parts diagram. Even with new bushes it's going to need something more.
Old 06-22-2015, 09:29 PM
porschetub's Avatar
Get the bushes in and go from there and make sure the steel centre bush is centralised properly,wow nice car and RH drive !!!!!!,has it been converted or original ?,rare colour also,cheers.
Old 06-22-2015, 11:28 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
There were no original RHD 914s, all were conversions. A handful were done when the cars were new, and a few were done on an individual basis afterwards. Crayford's in the UK did most of the when-new conversions.
--DD
Old 06-23-2015, 06:38 AM
Steve S
Thanks Dave. Crayfords did eleven RHD conversions in its time. 2 were for owners outside the UK and this is one of them. It was converted as a new car and was owned by a pharmacist in Double Bay, Sydney. I have a folder of documents from those days. It has changed hands a few times since then and I have owned if for 6 years.
Old 06-23-2015, 04:57 PM
