mike mueller's Avatar
More Trailing arm questions
Brad (or anyone else)
Is their a fixture or any magical numbers printed to allow me to check if my trailing arms are tweaked from an encounter with a curb or ????
'73 914, 1.7, with Boxster transmission in the future?
Old 11-12-2002, 10:17 PM
914 Geek
I believe that Haynes has a photo showing a couple of measurements. The trailing arm is in a vise as I recall.
--DD
Old 11-13-2002, 09:50 AM
Racer Chris's Avatar
Lightbulb Re: More Trailing arm questions
Zero toe and 1 degree negative camber, more or less, depending on usage. I think Hunter makes a fixture for this.
There is no factory spec, or fixture to check the trailing arm off the car. If you see a dimple in the trailing arm where the sheet metal looks like it should be smooth, then it's definitely tweaked.
I started making a fixture for this purpose after a crash, but never finished, since I have several spares. My plan was to make it sturdy enough to hold the trailing arm while I applied enough force to "un-tweak" it.
Chris Foley
CFR-Tangerine Racing Products, LLC - 914 Products and Services
Old 11-13-2002, 01:15 PM
