chrisreale's Avatar
Question Slight stutter when I am driving
Just noticed it today. I was going about 35-40mph. I was in 4th gear, about to move down to third, when i noticed a stutter. Felt like it was coming from the right side, maybe the rear. I was thinking it couyld be that I was getting my rpm's too low (I hadnt down shifted into third yet, and was only going 35). It doesn't happen when i am in third, or when I am speeding up, only at a consistant speed, around 35 0r 40, and the rpm's are around 2500 to 3000. Is this just the transmission saying it wants higher rpm's, or is this a rear wheekl bearing, cv joint...? thoughts appreciated.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/
www.914club.com
Old 12-09-2002, 09:44 PM
Brad Roberts's Avatar
Did it buck ??
Trigger points and/or pressure sensor can cause a bucking sensation.
B
Old 12-09-2002, 09:54 PM
todd914's Avatar
35 mph in 4th. Most likely nothing. Keep driving it and if it does it again try and conduct some controlled experiments to see if it's a gear*rpm related issue or something more.
Actually,the 914 is a "Poor Man's Porsche". You buy one and you end up poor...Or it ends up covered with Por 15? Either way, something's poor...
Old 12-09-2002, 09:55 PM
korijo's Avatar
chris,
Do you still have the wrong MPS? Makes sense of Brads reply.
Dave
Korijo
73 Olympic Blue 914 1.7L (2L /4 back in progress)
69 Highlander Bug 1776
93 GL EV 2.8L The Van ™
914club.com Member #914
Old 12-09-2002, 10:06 PM
chrisreale's Avatar
Yea, i got a 1.7 MPS. I am waiting for Bleyseng to fix up one he is going to sell me (*hint..cough Geoff*hint). I didnt know that the MPS could do this. Lernt sumfin nu tuday
www.914club.com
Old 12-09-2002, 10:16 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
I tested it in my car tonight, Chris and all is well.
Could be the TPS is mal-adjusted or old for that stutter at 2500-3000rpm.
Or what is the timing set at? Is the distributor new/rebuilt? A worn dist also will cause problems like this.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 12-09-2002, 10:53 PM
