korijo's Avatar
FI system compatability....
Will a 76 2.0L complete FI system fit on earlier years (73-74)? I would only need the same 3 stud intake port, correct?
THX in advance...
Dave
Korijo
73 Olympic Blue 914 1.7L (2L /4 back in progress)
69 Highlander Bug 1776
93 GL EV 2.8L The Van ™
914club.com Member #914
Old 12-10-2002, 08:17 PM
kellzey's Avatar
If you are placing it on a '73 or '74 2.0L, then yes, but if it is a 1.7 or 1.8 (1974) the sheet metal is different as the spark plugs are in different locations.
Do you have a California 2.0L FI system. If so, it may have some additional stuff on it that may rob it of power as compared to rest of state 2.0L systems (Cat converter, air pump ports in the cylinder heads, more restrictive exhaust).
Regards,
Qarl
Old 12-10-2002, 08:25 PM
Ornery Bastard
All '75-'76 cars have air pumps, regardless of CA model or not. The only difference is that the CA cars have the cats and EGR.
The '75-'76 2.0 cars also have a different ECU part number than the '73-'74 2.0 cars.
I remember that when the ECU on my '76 packed it in, I could _not_ use a '73-'74 ECU, I had to get the proper '75-'76 ECU. My car is a 49 state car and it doesn't have the cat.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 12-10-2002, 08:28 PM
korijo's Avatar
I more or less just want to know. Knowledge is power, huh.
Thanks guys...
Dave
Korijo
Old 12-10-2002, 08:37 PM
Bleyseng's Avatar
Send a message via ICQ to Bleyseng
The 76 FI will work fine on any 2.0L car as long as you use the matching parts.
The 73 2.0L is an odd ball system since it uses the same ECU a 1.7L. Thus it has the different CHT sensor with the ballast resistor and different MPS.
Aaron, I don't see any reason a 76 ECU wouldn't work fine in a 74 car as they are very similar.
Geoff
76 914 2.0L Nepal Orange (2056 w/Djet FI, Raby Cam, 9to1 compression)
www.914Club.com
My Gallery Page
Old 12-10-2002, 09:15 PM
914 Geek
The only reason I can think of that it wouldn't work is that the later thermo-time switch (I think it is) requires another wire that is powered by the ECU.
There might have been one other difference in the wiring and such...
Mind you, there is a difference between "fits and runs" and "fits and works completely correctly".
--DD
Old 12-11-2002, 11:03 AM
Ornery Bastard
Geoff
I was just pointing out that I couldn't go backwards in regards to the ECU. My '76 needed a '75-'76 ECU and couldn't use a '73-'74 ECU. I never said anything about going forwards.
Aaron
Old 12-11-2002, 11:43 AM
pbanders's Avatar
Send a message via Yahoo to pbanders
'76 ECU also has over-run shut-off, the '73 and '74 ECU's do not. The speed control circuit is also different, it has one more or less (can't remember) waveform generator. Check out my web page on ECU's for differences and compatability of components.
Old 12-11-2002, 12:41 PM
