Send a message via Yahoo to radobard
Early 914 ignition switch wiring
I am replacing my ignition switch on my 1970 914 4. I noticed this unfamiliar type of wire in my wire harness going to my old ignition switch. My new switch wiring does not have this wire. Here is a pic of the wire. Can anyone tell me what it is and do I need it.
Roland
Old 01-10-2016, 11:16 AM
914 Geek
Is that a wire? Looks more like a flat piece of paper?
--DD
Old 01-10-2016, 07:04 PM
It looks like a long flat copper stream in some type of see through wrap.
Roland
Old 01-10-2016, 07:10 PM
How does the Buzzer connector look and where does it connect in the ignition housing?
Roland
Old 01-12-2016, 09:54 AM
porschetub's Avatar
Roland
Looks like the wrap that goes around the wiring loom you will see more of it on the wires off the fuseboard,least that's whats on my car.
Don't worry it isn't wire,not needed.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 01-13-2016, 10:42 AM
But it connects to a pin in the electrical 12 pin connector under the dash.
Roland
Old 01-13-2016, 12:21 PM
if I recall there was 2 option for the ignition (with and w/o the buzzer circuit). I am guessing your original switch had the clear ground broke off from the switch and your new replacement did not have the buzzer option.
Old 02-26-2016, 05:13 PM
bowlsby's Avatar
That flat copper in a clear cover is the ground for the ignition key buzzer. It attaches in the mechanical section of the ignition key lock mechanism. This diagram should help:
Old 03-02-2016, 09:41 AM
