aircooled addict
jimbeaux911's Avatar
solid outer engine mounts ???
OK so here I am needing help again. COmes with putting together a car someone else took apart I guess.
I am doing the sideshift conversion on a 71. I am at the point of installing the engine YEAH! I have the trasmission mounts all cleaned up and ready to go. I installed new rubber INNER engine mounts to the crossmember. All is good so far.
In chosing what pieces and parts to use from my large box of misc hardware that came with the car, and the outer mounts that were hanging in the hellhole. and looking at diagrams online. It would seem that the OUTER engine mounts are not much more than a bolt, and a flatish plate a washer and nut. Is this correct? no rubber dampeners, or anything else to worry about?
I understand the original tailshift option was for non-solid mounts here, and many have suggested solid is the way to go with sideshift. so I am just hoping for some verification, as it seems odd to simply bolt it directly onto the car with no rubber vibration absorbing material at the outer attachment points.
Thanks in advance!
Jim
someday I will actually get to drive a 911
Old 03-27-2016, 05:47 AM
914 Geek
The outer mounts were a piece of U-shaped metal. The sides of the U give it extra strength against bending. The washer that goes on top of the mount has trimmed sides so that it fits in the bottom of the U.
If you use the tail-shift outer rubber mounts on a side-shift bar, it will sag and interfere with the rear shift rod. You won't be able to get some gears. Not usually regarded as a good thing...
--DD
Old 03-27-2016, 08:22 AM
