K&N filter systems for 2.0
Greetings all, I have stumbled across a K&N filter system for 2.0 914's. I have a similar system on my truck and love it but am not experienced with the outcome of the system on teeners. This system replaces the entire air intake box, attaching directly to the throttle body. Air dependent hoses have barb attachments on the body of the system. They claim a boost of 8-15 hp. Not bad for $100.
Any comments? Thanks, Scott |
Ha ha...
I dyno tested a stock 2.0 with and without the air cleaner and picked up 3hp without it. I dyno tested a stock 2.0 with a header and K+N filter in the stock housing and and picked up 4hp from the stock air cleaner and filter. The same car without the air cleaner assembly picked up another 1hp. Ask for the dyno sheets. They are full of Sh_t up to their eyebrows. There is NO way a air cleaner (alone) can do this. Welcome to Ebay. B |
If this is what you are looking at, I believe that others here have built their own with PVC. I'm sure someone will chime in soon.
That's what I was referring to. Couldn't get the pic posted. Would be interested in folks thoughts on that intake system.
Thanks again, Scott |
It looks cool.
The biggest increase I have see: Moving the snorkel of the factory air cleaner around so it picks up a little cooler air from the drivers side of the engine compartment where it is less cluttered. Who am I ?? Buy it and do some dyno pulls and report back to us. Had to stop and think.. I dont care if you buy or not... LOL Paul.. how many people do you think actually hit your "search" button ?? B |
Just once. I did it.. and I knew better.. LOL
Cool if you could make it search your site. B |
Puny Bird
Does K&N make a filter that fit's the stock 2.0 box? is it worth it?
Hi Mark,
This topic came up about a month ago. Here's a link to the thread: K&N Air filter worth the $40-$50
Malaga Red '76 |
Stay away from my Member
There is a K&N drop-in replacement filter. I doubt if it is worth doing. Maybe 1hp if you are lucky, and read the zillion posts about potential increased particulate intake and make your own judgement before you spend your $50.
Also for anybody who cares, PCA & POC stock-ish classes (track events) usually require you to run an unmodified factory airbox. You can use the drop-in K&N or no filter element at all if you want, but not the full "snorkel" setup like the pic above.
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
BTW I think I'm gonna run the ITG reticulated foam filters on my six. I have K&N's now on the IDF44's on the 4-banger.
Puny Bird
Doesn't sound like it's really worth it.
They are $63 Canadian here, that means that in US dollars, they are cheaper in Canada, go figure that out . |
Like I posted above.. to stay legal with the classes.. flip the snorkle portion of the air cleaner around and pick up a little cooler air. This is just legal in the stock classes.
I think the K+N for the stock setup is fine. B |
