Good Evening,
Take a look at these pictures and give me your thoughts on using these heads. All 4 chambers look like this. ![]() If I should not use them as is, can they be saved?
Robert 1975 Porsche 914/4-2.0 1972 Ford F100 Ranger XLT 2006 Ducati Sport 1000 323i.net RangerXLT.com |
No advise on condition, but a good sand/bead blast would make it much easier to determine the condition. Not an educated comment, but the scalloped area around the intake valves looks fishy. They could be fine though.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
in the top picture, the black area in the 6 o'clock area reminds me of what my machinist said was leakage out of the combustion chamber. he also said many type IV's do this. so, Jake, is that correct?
The "head gaskets" on both cylinders were blown.
The "scalloped" areas are where the seats were welded in. My intital thought about this is "idiots" but maybe that was the thing to do back then.
No expert but
Here is my .914 cents worth. Disassemble the heads and sand blast the whole thing. Wash them up and then see what you really have. Cracks can be fixed if you find a compitent welder.
I would be concerned about the "cc" of each combustion chamber ain't no way they are the same. Get on the PP tech articles and find the work sheet to figure out compression ratio. Smooth out blend these ridges and match all four combustion chambers. I don't personally use head gaskets but I do lap each cylinder to the respective hole. While you are at it and feeling pretty good about your grinding skills by then, polish up the exhaust ports and match the ports to the pipes. Don't forget to lap the valves when you put them back in. Looking at your pistons yup they are U.S. No biggy they will work just fine. |
I should add that the heads were "redone" by a local place called Dover Cylinder head many years but very few miles ago. (like maybe 1500 miles) I've got to pull the valves to Helicoil and plug the smog port holes any way but my valve spring compressor is not at home.
They are pretty clean other than the chambers.
Still no spring compressor at home, but some cleaning shows the seat (darker area) under the weld. It appears that the weld was allowed to flow over the seat. (it's also visable in the other photo) Anyone ever seen something like this before? Would "Big Valves" repair these areas? Last edited by DuckRyder; 12-23-2002 at 06:38 PM.. |
From my perspective, it appears that the seats were sunken and a ball mill/grinder was used to (try to) blend the edge (badly, I might add).
The beauty of aluminium alloys is that most diasaters can be fixed (heliarc - not welded). Same goes for the smog port holes - they could be heliarced closed rather that the drill, tap, helicoil, plug method. Just an opinion and yes, I would use them after I had a good head shop look them over. Better now than after they "drop" a seat at RPM. Ah well.............,
"Inventor - Blue Flame 914 Seat Heater" "Yellow Rusty Cars Are Faster" _____________________________ '70 2.5 (I'll never finish it - Somewhere over the rainbow.....,) '73 2.0 (Just Not The Same) '74 2.0 (Heartless & Lungless) |
ASE Master Tech - 35 yrs
done by some numnutz with a drill & grinding stone; if the valves are seated o.k. and it's just a casual driver, go ahead & use 'em, but if the seats are screwed up too, they are junk.. will cost more to refurbish than a nice set of used ones
914 Geek
Oh, here are the head pics....
From the one pic, it appears as if you may have one sodium-filled exhaust valve and one that isn't. (One has the dimple in the valve face and one doesn't seem to.) An ugly combination, if true. Sodium-filled valves are not very commonly available in larger than stock sizes, so it is likely that this head has stock-sized valves. This set is odd enough that I would stop asking a bunch of amateur-type enthusiasts (that's us), and find a good machine shop with Type IV experience and see what they have to say. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
I agree with Dave, take it to somebody who KNOWS what they are saying is FACT. We can barf put opinions all day, but a true head shop will tell you what you need to know. If I waz U, spend the coin to have a head job. In afew months, when your driving the car it will be all worth it.
I agree, but there isn't any one around I really trust except Jake and I don't really think he is game for doing just heads, and in all honestly, as much as I'd love to have one of his motors, money is a little tighter than that at the moment. I was given the name of another fella Steve Sands I think in Lithia Springs or Villa Rica but all I really know about him is he's built some T1 and TIV motors for the locals.
I've pretty much decided to either have these worked (again) or find a place that will trade take them on cores. Any one got a nice set of non-smog cores? I just wanted some opinions to help calibrate my BS meter. If it were a Small Block Ford I'd know what to do, but it aint.
Robert 1975 Porsche 914/4-2.0 1972 Ford F100 Ranger XLT 2006 Ducati Sport 1000 323i.net RangerXLT.com Last edited by DuckRyder; 12-29-2002 at 06:27 PM.. |
Why not ship them to Jakes head guy?
Adrian at Headflowmasters in LA? Or Rimco...also in LA? |
Also, When I get a couple of valves out I'll post up again. The keepers are doing a fine job of keeping, and I ran out of time to mess in the garage today.
It appears that the head material overlaps the seat.
That would lead me to believe that someome attempted to hold the seat in by swaging or staking, but made a hash of it.....(basicly, pushing the aluminum over the seat). Roller swaging might be a good fix for t-4 valve seat problems but it is a one time deal. It works well in many applications...if done correctly.....this job don't look too shiney. Maybe this is where the term "hammered s**t" came from.
JPIII Early Boxster |
Got the valves out today. Here is what I found.
Valves are stamped "ATE" and appear to be the stock valves. No word from HeadFlow Masters yet.
Man! That is the air injection hole in the exhaust....ugh.
To me it doesn't look like the valves were completely sealing. (don't forget to lap them. If you are short on funds like me you should just smooth all the rough spots. cc match all four combustion chambers and get that engine back together. Drive it like a sane person and enjoy. If you drive like me and a few others on this board spring for a new set of matching heads then DRIVE IT. BTW "TIG welding" has been a life saver on my heads.
