If anyone is interested, failure of an external oil thermostat to close, thus routing cold oil to an external oil cooler
gives you this: |
folowed by this:
A fine mess. JPIII |
JP,
And your garage WAS so clean. You didnt blow this while the car was running did you? Was this all due to a bad thermostat? Kelly |
I was starting the car in the shop preparing to go autocrossing.
Tho I haven't pulled any parts yet, the thermostat (external) is supposed to route cold oil around the external cooler.....just to protect it from excessive pressure. No oil should have been going that way. It pumped out about 10 quarts in maybe 20 seconds. All thru a split maybe 1 1/2 inch long X .03 wide. A fine mess. Troutamn thermostat, BTW. JPIII JPIII |
JP....just courious, where did you mount your external oil cooler?
SAC
When I had my boat I used to throw 50 dollar bill at it when ever I went to the dock...now I do it when ever I open the garage door. |
Bummer
At least it happened stationary, and not while driving.
1973 914 2.0 PCA Member GGRwww.pelicanparts.com/gallery/chrisreale/ www.914club.com |
Unregistered
LOL, I bet JP's gonna be real happy to see this thread come back to life.
(inside joke). |
Oh geez.... I should've known someone would have to start this up again (sorry, JP)!
Scott 74 914-6 2.7 |
canna change law physics
Bad 914. BAAAAAD!!!! BAAAAAD!!! (swap with newspapers on the nose)
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
