six conversion engine mounts
does anyone have any experience with the different kinds of engine mounts: patrick, pelican, rich johnson?
BH |
The best one, IMHO, is the bulk head mount made by Rich Johnson.
914-6 3.2
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
thanks jim, that is the same response i got from brad and others on the 914 club BBS
brian
74' 914 (in pieces) 00' 929RR |
Rich Johnson Mount
anyone got a picture and how much is it. What is the level of difficulty in mounting it properly on the bulkhead?
Administrator
Check here:
http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_sixcon_main.htm Not that difficult, but it does have to be welded. It can be bolted in place first, but that isn't very good for the long term. Usually just long enough for you to get the car over to someone who can weld. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Here's a picture of the bulkhead 6 mount from Patrick M/S. He sells it as both bolt-in and weld-in. Major brick outhouse design, very easy to drop the engine with the two bolts (and the tranny mount) (and oh sh- (yeah), the tranny ground strap).
John Yellow '76 914 3.2 YPAF |
I'm running the Rich Johnson mount with my 3.2. I'm also running factory heat exchangers. You can't run the factory heat exchangers with the crossbar mount.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
