Axle lenghts
I a building a 550 replica with 914-4 running gear including engine, gearbox and suspension
The problem I am trying to sort right now is the angle and length of the axles Please have a look at the picture, does the angle look too sharp? I can't move the engine/gearbox any ,ore forward because its already hitting the firewall. I guess if the angle is still sharp, I might have to cut the firewall and form a bulge which is not a big deal My bigger issue is the length of the axles, they seem too long. If I bolt one axle on, it pushes the gearbox about 60mm off center Is there two different axle lengths depending on the gearbox? Thanks for the advice Rafik |
914 Geek
Not sure about the angle, but it does look uncomfortably large. You'll want to check through the whole range of motion as well.
There is only one length of 914 axle. I believe the 911 axles are shorter, so you may want to look into those. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Thank you
My next question is what is the axle length of a 914 and a 911? |
ASE Master Tech - 35 yrs
looks like your 550 was designed for swing axles
suggest you ask questions on The Samba and see what the VW guys have for solutions - they do a lot of swaps & conversions also read these - several of your issues are addressed in them - Replica Porsche 550A-6 Spyder- 550 Against The Clock - Hot Rod Network - Flat 6 Porsche engine question | SpeedsterOwners.com - 356 Speedsters, 550 Spyders, Replicas and more .
"... I am German, and if it has no logic it's meaningless." 914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Thanks, will read the articles
But no, the chassis was designed for 914 trailing arms setup |
