jrblackbox's Avatar
Trans leak at CV
In the middle of my 5 lug conversion. where the CV joints attach to the transmission, it appears that both sides have leaking/seepage. I have tried searching but I really don't know what I am looking for. Easy, or too much, not worth the effort, don't bother? Gaskets, bearings? TIA
Old 10-29-2017, 08:24 AM
914 Geek
Seals. You replace them by removing the axle flanges from the transmission. I haven't done this job with the trans together, so I don't know how difficult it is.
--DD
Old 10-29-2017, 09:27 AM
jrblackbox's Avatar
Thanks Dave, part number?
Old 10-29-2017, 09:42 AM
914 Geek
The PET says: "999 113 183 40 radial shaft seal 45 X 68 X 10"
Aftermarket, $5
OEM part
--DD
Old 10-29-2017, 08:36 PM
Rescuer of old cars
Arne2's Avatar
Piece of cake to do, no disassembly of the transmission is required. Unbolt the CV, there will be a bolt in the center of the flange. Remove it and pull the flange off. Clean and replace seal, put it all back.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-29-2017, 09:09 PM
jrblackbox's Avatar
Thanks all!
Old 10-30-2017, 03:11 AM
Double Trouble
targa911S's Avatar
yep. easy job.
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 11-01-2017, 06:19 AM
