140# rear spring question
I just purchased a set of 140# rear springs from a list member. He stated that the free length of these are shorter than the stockers. What issues will I have with these. In my thinking, if they are loose on the shocks at full extension, then if the car unloads them while going over a bump, the spring can shift to a side and become disloged from the perch.
What am I looking at here, any tips tricks? Next, should I install them on a new set of KYB shocks I got, or put them on the original Boge units that have 100k on them. Some say the KYB's are too harsh. Just trolling for suggestions.
Sasquatch 1987 Porsche 944 1974 Porsche 914 "Don't retreat, reload." Sarah Palin |
914 Geek
Tie-wraps will keep the springs from unseating themselves. You may have to drill holes in the upper spring perches for the tie-wraps to go through.
Not sure on the KYBs, though I would guess that at 100K miles, the Boges probably do need replacement... --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
i had to cable tie my 140's to the lower perch on a 72 without a rear sway bar. one corner going to the house was more fun than i could stand. the springs popped out every time.
you might slide hose on the ends of the springs to keep them quiet. i think you have to remove some of the snubber on konis. check out if you need to do that with the others kybs harshness might match the stiffer spring. i would at least try it.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday |
Unregistered
I did the drill and zip tie trick on my 200# springs. worked jus fine. I got tired of changing the corner balance every time I jacked up the car
If I remember rightly, the upper spring perches on the Bilsteins are kind of conical, which makes them self centering. I had seen others tie wrap to the lower perches (that's what you meant, right Dave?) but I haven't had an issue with mine and the springs are completely loose (about 1 inch of play) when the suspension is at full extension, like jacked up in the air.
BTW, the 140# springs I would think are going to contribute more to ride harshness than the KYBs will. My $.02? Put the new shocks on (you'll get better response from the suspension) blame the harshness on your new "suspension package" and enjoy a whole new way of driving that car!
Herb '72 Tangerine 'Teen 2.4 liter aluminum handgrenade |
I am looking forward to it. This is this weekends project as well as replacing the clutch cable. I hope it is as easy as on my old VW's.
My experience with KYBs is limited to those I had on the rear of a 73 9eleben. They earned their reputation of Kill Your Back.
With Konis on the front, bumps would produce a "thump-bang". It gave me a good comparison. With Bilsteins, the 140 springs are not unduely harsh, even with 50 serise tires.
JPIII Early Boxster |
