Anyone know if there is a difference between these 2 injectors?
Can't seem to find any reasonably cheap injectors for my 1988 924s so I've gone down the cross referencing route. OEM part number on my injectors is 0280150158. I can't seem to find anything interchangeable with that number so I started looking at early 944 fuel injectors (94460611001). There appears to be many options with the part number from the 944 but my question is are these injectors the same as what's in my 924s?
Sent from my iPad using Tapatalk |
https://motorwestperformance.com/fuel-injector-flow-rates-and-specs/
The Bosch number for the early injector is 0280150201
Good luck, George Beuselinck Last edited by 944 Ecology; 07-06-2018 at 06:13 AM.. |
The ohms rating for my current injectors is the same as the 944's but the flow rate? Is different. I don't know the unit of measurement used here but my current injectors are rated at 240 while the 944 injectors are 250. What difference would changing over to the 944 injectors make in regards to performance?
