Replacement Factory Studs
HI all,
I am rebuilding my 968 race motor after something go sucked into the intake and damaged the bore. I have had to remove all of the studs to get the bore replated in Nikasail, Some of the studs were damaged during removal and need to be replaced, I am not super keen of getting race ware studs etc as they are expensive. Anyone know of a source of factory studs? Or a Std stud kit? Cheers Rob |
The factory part number is 944 101 197 03
Lindsey Racing has a listing for that part. as does the host of this forum.
Good luck, George Beuselinck |
HI All,
The head studs are ok, its most of the others, water pump studs, main bearing studs etc... I cant find anywhere that has them, and pet etc doesnt list a part number, Cheers Rob |
water pump studs you can get in a kit from 944online or just hardware store.
there are no extant part numbers for the main studs - Porsche considered them integral to the block itself - but Raceware sells their own replacement kit. |
