rbt944's Avatar
Angry My coolant, where is it going???
Hi there everyone. I have noticed that the coolant in the reservoir keeps getting low so I have to keep adding. Usually when i drive for a long period of time it smells like a fart and I can assure you that it's not man made The car has never really overheated the temperature needle has only gone as far as to the middle. It's had this problem for quite some time now. There is no noticeable smoke that I have noticed. I'm suspecting a gasket but how can I be sure???? Thanks for looking.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 03-04-2003, 12:42 AM
AFJuvat's Avatar
How much are you losing? Some drop over time is normal, adding a few quarts a week is bad.
Clean up the engine, remove the belly pan and run it in the garage for about 20 minutes - shut it down and check for leaks
Fart smell (rotten egg stench) is usually catalyst.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-04-2003, 03:59 AM
Bay Area Patriot
TheStig's Avatar
If he's losing a lot it could be the lower radiator hoses. I had a leak there.....then the upper one leaked....
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 03-04-2003, 12:45 PM
Pam B's Avatar
Send a message via AIM to Pam B
Hey...I knew that....Watch out....I'm actually learning something here!!!
Old 03-04-2003, 01:06 PM
rbt944's Avatar
I usually check the reservoir somewhere around every 2 to 3 weeks, by then it's usually empty. I don't really drive the car that much. I just filled it up tonight and I will start checking periodically to be exactly sure how long the coolant lasts. There are no puddles of any kind under the car when it sits for a while but I will do what you suggested AFJuvat as soon as it stops raining.
So I take it that I may have to replace my catalityc converter. I live in California, has anyone installed a less restrictive converter on their car and passed smog? What are other brands that are just as effectve and leave the wallet full that someone would reccommend.
-Gus.
-Gus
2000 kawasaki zx6r
1984__944.
pictures
Old 03-04-2003, 08:03 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Hrm... I am in the same boat you are.
However...
I have a crack in my radiator.
The sides are plastic and crack easily. Mine has a small crack, so when it heats up, it leaks a little. So, when car is stopped, off, it is cooling down, so no drip.
Check the radiator if you can't find anything else.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 03-04-2003, 08:40 PM
