Rear Wiper Blade Question / no pin on replacement
86 944 Turbo, needed a new rear wiper blade, bought the Porsche genuine blade # 928-628-218-02. Car has original rear wiper arm on it.
Old blade on car has a seemingly non-removeable pin on the side of it, that goes into the side of the rear wiper arm. New blade, no pin.
I don't seem to find blades with pins anywhere(genuine or aftermarket). Surely I'm overlooking something stupidly simple here.... Anyone have ideas?
Old 11-26-2018, 03:02 PM
GO AWAY! Stay in Cali
Swennydawg's Avatar
On my '87 924 I used a small nut and bolt to hold the assembly to the arm. I repainted the whole wiper assembly and the MacGyver is holding up and looks as good as an assembly can.
Old 11-27-2018, 04:24 AM
Thanks @swennydawg - very Macguyver indeed and I had the same thought. However - there's got to be a real way to do this without buying a new wiper arm (later style with the clip instead of the pin)
Old 11-27-2018, 11:22 AM
i pressed the pin out of my old wiper quite easily and reused it
Old 11-28-2018, 06:25 AM
thanks @RedCarGuy - I guess I'll try that. I tried to remove the pin but... will give it another go.
Old 11-28-2018, 06:23 PM
Send a message via Skype™ to massive
How did you manage to press the pin out? Mine is very very fixed to the wiper blade frame
1984 944, 2.5L, manual transmission, UK right hand drive.
http://944foot2thefloor.blogspot.com/
Old 07-14-2021, 02:20 AM
support the edge and use a hammer or rig up a clamp with a socket underneath. it isn't welded in there, it will come out.
Old 07-16-2021, 03:48 AM
Is the pin in two parts? As the bit in the centre sandwiched between the frame of the arm looks a bigger diameter than the pin part that sticks out?
Old 07-16-2021, 04:20 AM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
I didnt get a rear wiper on my 86 951...
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 07-16-2021, 07:05 AM
universeman's Avatar
I look at things like this in the following manner: It had to get put together, so it has to come apart. Can it be pressed through from the larger side, i.e., apply pressure to the thin end?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 07-16-2021, 07:06 AM
Push on the small diameter side as universeman says. The pin is one piece.
Old 07-16-2021, 12:39 PM
