Help something’s wrong
Just got home and parked my 87 after driving about 60 miles. Filled up with gas just before leaving earlier. Went back out to repark the car. Car started fine as it always does idled for about 20 seconds then went into rough idle and shut off. Tried to restart idle was really rough for about five seconds then just dies. If I apply throttle it stalls right out. It’s late and I’ll start to troubleshoot tomorrow any ideas. Car has approximately 235k but always maintained and runs fantastic (until now). Thanks
78 911 st backdate 87 944 00 996 |
944 addict
Was the car left on an incline? If so, roll it to a flat area and see if it works better. You may have to run it a little to clear up the fuel line. I'm suspecting water in the gas from your latest gas-up. Outside of that my next thought would be the DME relay. If you don't carry a spare, I would recommend it. Get a Stribel or OEM....avoid the URO brand. They're crap right out of the box. Good luck with this.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
In the Fires of Hell.....
Could also be speed/reference sensor connectors.
Look for the holy trinity: Compression, Fuel, Spark
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Yeah, this was a recurring problem with mine until I replaced them. But on mine it wasn't the connectors themselves, it was the wires just before them cracking and breaking.
Pelican Parts Vendor
Most folks probably haven't heard, but we completely redesigned our DME relay 993 615 227 01 in early 2018. This new 3rd-generation relay uses modern modular design and is assembled using Surface Mount Technology (SMT) for consistent quality and long-term reliability.
We'd be happy to offer a warranty replacement to anyone who had one of our old DME relays (p/n 993 615 227 01) fail in the past, just contact us with your purchase details at "sales at uro parts dot com" (remove spaces).
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 01-18-2019 at 10:47 AM.. |
Fixed!!!
Ok so I started by changing the dme and it didn’t change. Then went to the maf ,still nothing. Then noticed a weird clicking sound coming from the idle air control sensor under the intake manifold. The wire harness had been worn by rubbing against the intake manifold and was arcing out. Insulated the wire and bingo 4 hours of driving and shutting the car off and on various times no issues.
944 addict
Good to hear.
944 addict
Excellent!!!
curtisr
+1 Uro.
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold) 1987 924s Garnet Red (currently becoming Lowencash II) 1982 928 Silver (sold)
mine arrived today!
Thank you URO! M
924S - 1988 |
