Question Price to get syncros installed
Well I know the time is drawing ever closer to replace the syncros in the transmission... between 1st and 2nd it just dosn't sound good... :-( especially when its cold. So I thouth I'd ask you how much I could expect to pay for a job like this.
Old 03-15-2003, 12:08 PM
Rennlist Member :)
Scootin159's Avatar
Re: Price to get syncros installed
I'd like to know as well, mine's getting kinda messy in there as well (1st & 2nd). I'm gonna try just changing out the tranny lube first, I've heard that can "fix" a lot of problems (plus it's just good preventative maitinence).
2006 Subaru Impreza WRX STI
1989 Red Devil F440
Former: 1987 Porsche 944
Old 03-15-2003, 12:21 PM
Ornery Bastard
Scootin', you could also try what the truckers do and shift without using the clutch. Of course, it's not very forgiving of mistakes.
On a more serious note, try double clutching. It's not too hard to learn and it will really smooth things out.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 03-15-2003, 12:23 PM
AFJuvat's Avatar
Synchros - looking close to $1000 to get them done. More if your synchro hubs (a.k.a dog teeth) are shot
Total tranny service, around $2000
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-15-2003, 05:25 PM
suck my tail pipe
Frank B's Avatar
Send a message via AIM to Frank B
Double clutching soleves and prevents alot of problems. My Willy's didn't have any Synchros.. so I either double clutched it or gave my tranny a beating.. if the synchros are going you can do it yourself.. taking out andre-installingthe trans will take longer than replacing the synchros..
My car is naughty
Old 03-15-2003, 05:32 PM
AFJuvat's Avatar
Actually......
Small disagreement on that point.
to get at the synchros, a few pieces need to come off.
for those pieces to come off, you need a puller to get them off the shafts.
To get them back on the shaft, you need to heat them up to over 230 deg F.
Need to freeze the hub and heat the synchro to get it in, it is a tight press fit.
see attached image, you are looking for part 5, 19, 35, and 38.
AFJuvat
Old 03-15-2003, 05:50 PM
suck my tail pipe
Frank B's Avatar
my bad.. I forgot about the freezing/cooling issue....I do suck..
My car is naughty
Old 03-15-2003, 05:55 PM
Send a message via AIM to Trevor
Rev match, makes the shifts smoother and then you don't need the synchros.
1987 Black/Black (sold)
96' Jetta (RIP)
1986 N/A (Sold)
2001 Taurus noooooooooooooo!
1993 325is
Old 03-15-2003, 06:07 PM
coupe's Avatar
How about getting a used gear box, wouldn't that be cheaper?
coupe
http://www.p-caronline.com/directory/coupe
Porsche 944 Turbo, 1986
Fiat Coupe 20v Turbo, 1997
Old 03-15-2003, 09:44 PM
AFJuvat's Avatar
Exactly
Surprisingly, 911 gearboxes are much easier to work on than 944s are
AFJuvat
Old 03-15-2003, 09:48 PM
looks like i should start looking for a deal on a gearbox!
Old 03-16-2003, 01:33 AM
overkill's Avatar
Send a message via AIM to overkill
Think about it, how much for a new or should I say used gear box? I would fork out the money nad have your tranny worked on because it will be an almost fresh tranny. I mean that is if you didnt do alot of grinding. Thats what I would do but then again whos car has been sitting in a driveway for how long?
{1987}944S - (SOLD).
Old 03-16-2003, 07:09 AM
