Auto Tranny Fluid Recomendation
I recently purchases an 89 944 with and automatic. I am planning to drop the transmission pan and change the fluid and filter. What have you used and would recommend? What is called for by the factory? -Rick
-Rick Central PA
1989 Linen Grey Metallic 944 Automatic (Daughter's first car)
1984 Slate Blue Metallic 911 Cabriolet ROW, 220 WHP, Steve Wong Chip, Fabspeed Muffler, Cat Bypass.
1987 Black 944S - SOLD 1969 Aubergine 911T - SOLD
Old 03-12-2014, 04:17 AM
ernie9944's Avatar
There you go!!!
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
Old 03-12-2014, 06:00 AM
Auto Tranny
Thanks.
-Rick Central PA
Old 03-12-2014, 06:12 AM
Dexron.
Good luck, George Beuselinck
Old 03-12-2014, 07:51 AM
1987 944
Originally Posted by ernie9944 View Post
There you go!!!
Last time the ATF was changed in 87 944 used Dextron 2. Is Dextron 6 compatible with Dextron 2??
Old 07-25-2019, 10:26 AM
9FF 9FF is offline
9FF's Avatar
LMGTFY
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 07-25-2019, 10:39 AM
Yes all versions of Dexron are backward compatible.
However I would spend a little more and get more than than the basic fluid and get the best.
RedLine, Mobile 1 Synthetic ATF, Valvoline Synthetic ATF, etc.
You don't want to be replacing or rebuilding your 30 year old transmission.
Old 07-25-2019, 02:50 PM
