How smooth idleing is an '86 951?
I was sitting in my car with a Porsche workshop service manager a couple of days ago, and I pointed out that my cars still shakes and shuders while idleing even after all the repairs that I have done, including new engine mounts.
So he said that even if a bought a brand new engine, the car would still vibrate in idle and feel rough. I really just stopped listening to this guy at this point. I thought that this guy doesnt know what he is talking about. So my question to you all with better cars, How smooth are these cars, especially a 951 made in 1986???? Thanks.
coupe http://www.p-caronline.com/directory/coupe Porsche 944 Turbo, 1986 Fiat Coupe 20v Turbo, 1997 |
well, i have an '86 which britwrench says the motor mounts will soon go bad, yet it idles smoothly. so i think your problem isn't the mounts, unless they were installed incorrectly, which seems unlikely.
fiat pics? ![]() |
Mine is smooth when it is warmed up if and only if the AC is off. But what is smooth? It is not as smooth as my 400E V-8. It does not stumble or shudder. It is fairly smooth. Has your flywheel been lightened by any chance? Hard to quantify.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
Mine is very smoothe in comparison to other cars, even newer cars. In fact I can't even usually fell the engine running.
But this was not always the case, I had vacuum leaks and a torn J-boot that caused the thing to shudder at idle. I would bet that if you have good compression then there may be another issue.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Well, the way I see it is that it is way to rough for a Porsche. As far as I know the car is full stock, with the exception of a free flow exhaust system and the removal of the catalitic converter.
Fiat pics for Blackfoot
This car is a 2000 cc 5 cylinder, 20 valve Turbo charged developing 220 BHP. Year model 1997
0-100km/h in 6.5 s Top speed 250 km/h This cars engine is really smooth even with 5 cylinders
I can feel mine running but it is smooth.
Didn't see any trees in the background of your Fiat pix. ;-)
It should be fairly smooth. To compare, I put a glass of water on the intake manifold @ idle, and the water did not seem much different vs. a 98 honda v6 in top shape.
Ahmet
Cheers! |
Does the 951 have balance shafts?
Roger Hall 81 924 N/A Some people are like Slinkies. Not really good for anything, but you still can't help but smile when you see one tumble down the stairs. |
Yes
suck my tail pipe
of course.. sounds like the belt is not aligned
My car is naughty |
I'm getting the timing belts looked at again this coming saturday, as some of you may know, my new mechanic got them fitted wrong.
I have also ordered a new distributor cap and rotor, and new 8mm ignition wires. I hope all this will smooth it all out. I also have to look closer at the after market exhaust system fitted, and may have to renew most of it. I think that one of the problems may be here.
Thread Tools | |
Rate This Thread | |
