Have 944, will restore
mazdaverx7's Avatar
No Power to Instrument Cluster
Having an issue in my 85.2 that I'm trying to solve. The instrument cluster lost all power the other day when I started the car to move it. It worked initially and then went dead. I checked the fuse and while the fuse is good, I do not have 12V present at the cluster fuse, which is indicated to be in fuse location 18. I was wondering if there was a wiring diagram out there somewhere (I do not have a FSM) that someone could post a picture of of if someone has had a similar experience and they could point me in the right direction. Does power have to come through a relay first? Do the contacts that the fuse blades make contact with like to spread? Just trying to get this issue solved and I appreciate any help!
85.2 944 Guards Red M456 5spd
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
84 RX-7 GSL-SE/ 88 RX-7 10th Anniversary
04 RX-8 Brilliant Black 6spd/ 04 RX-8 Nordic Green 6spd
84 Corvette 4+3, 93, 95 Corvette 6spd, 18 Camry SE
Old 04-26-2019, 04:01 AM
