gearhead290's Avatar
Send a message via AIM to gearhead290
Angry I Hate My Car!
I've had it back for less then two weeks, low and behold it breaks...again. This time I took out the valvetrain (that's what my dad said anyways), it started doing it on the interstate and I was in the middle of nowhere so I just kept on driving, inexperienced and I kinda panicked. I think the cause is that I ran it too low on oil, but this oil change only had 1000k on it and I never would have dremt I would burn 4 quarts of oil in 1000k. Any advice on fixing it?
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 03-20-2003, 03:41 PM
stray15's Avatar
Send a message via AIM to stray15
whats its doing?
Old 03-20-2003, 03:50 PM
AFJuvat's Avatar
How does one take out the valve train - except by breaking a belt (or breaking a valve...)
running it without oil - you have bigger problems than a trashed valve train - like burned rings, spun bearings, scored cylinders etc...
What happened, walk us through your problem -= symptoms, etc. What were your gauges reading?
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-20-2003, 03:54 PM
pearldrum's Avatar
Send a message via AIM to pearldrum
Porsche Crest
Trust me, I know how you feel, i finally got my car running. Then drove for 20 minutes and heard knocking, it was a major let down...
'83 arctic silver 944 n/a
Power steering? who needs it!
Old 03-20-2003, 04:06 PM
Hmmm, I think it has something to do w/ the 3rd gear "chirp". JK
Old 03-20-2003, 04:31 PM
Nabeel's Avatar
Send a message via AIM to Nabeel
I Hate My Car!
I'm sure the feeling is mutual.
j/k
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 03-20-2003, 04:33 PM
I was just driving and it started making the sound a lifter does, but it was A LOT louder. When my dad (a mechanic) got home he said it sounded like the valvetrain was out. Any way you look at it I don't have the cash to fix it because of the whole tranny thing.
Old 03-20-2003, 06:14 PM
Scott R's Avatar
Take any hard croners with a suspected low oil condition? If so you may as well pull the motor since the #2 rod bearing is probably gone.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 03-20-2003, 06:19 PM
88_944's Avatar
If runing the engine with very low oil and all those bearings, valves etc sounds, sounds like a top and bottom engine job. I would just buy a used engine. Save $$ and time.
My Black 944
My Gaming Forums. Xbox360gen.com
Old 03-20-2003, 07:47 PM
Maybe the "chirp" in third gear was actually the squeal of metal-on-metal in the engine due to low oil. This is why children should not play with men's toys.
"ABUSE IT AND LOSE IT!!!"
Even professional racers, with their equipment maxed out for strength, power, and durability don't abuse their vehicles until after the race - and even then, only when they do victory donuts.
Stay Posted - more to come.
Old 03-21-2003, 05:07 AM
Yeah, it was stupid of me to be out screwing around with it. But it had been so long, I just needed to go and play. I'm sure you've all lost your car for awhile and had to screw around when it got back.
Old 03-21-2003, 05:25 AM
Yeah - I feel the same way about sex - it's been so long since the last time!!! (..... sigh)
Old 03-21-2003, 05:34 AM
SoCal Driver's Avatar
Shouldn't have got married!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-21-2003, 06:51 AM
Tell me about it - you haven't lived dangerously until you've lived with a woman going through menopause!!!!!!!! At least the first 30 years were good.
Old 03-21-2003, 06:59 AM
Friend of Warren
Re: I Hate My Car!
Do the words "preventative maintenance" mean anything? On any car at least once a week you should as a minimum check the oil level, brake fluid/clutch fluid level, tire pressure, head lights/tail lights, brake lights, signal lights, grab each tire and pull it out at the top to check for wheel bearing play. I'm sure others can add to this list. But the above should take only 5 minutes out of your tv/video game watching day. If you trashed your engine from lack of checking the oil level you get no sympathy from me.
Kurt V
Old 03-21-2003, 07:02 AM
Yep, sounds like an expensive lession...Good luck with her...& Sorry to hear of that problem.
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 03-21-2003, 07:31 AM
Re: Re: I Hate My Car!
nobody is perfect. I would check all of that when I changed my oil, which was every 2500 miles. I did mean to check it everytime I put gas in it, but I would always forget. Just proves that ignorance is kicking my butt!
Old 03-21-2003, 08:28 AM
AFJuvat's Avatar
Very expensive lesson.....
Don't hate the car, the car did not fail you, you failed it.
Poorer but wiser I hope.
AFJuvat
Old 03-21-2003, 08:57 AM
AFJuvat
Excellent Comment!
Old 03-21-2003, 09:03 AM
least common denominator
scottmandue's Avatar
j/k
Ditto here...
But not kidding.
Checking oil = good
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 03-21-2003, 09:17 AM
