ae1969's Avatar
Send a message via ICQ to ae1969
Bench testing Manual tranny....
Ok so I pulled the tranny out....
Now I would like to bench test it....
Under load and at higher gears ...horrible grinding sound from the rear of the tranny...
So any ideas on how to spin the input shaft....
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 03-31-2003, 03:15 PM
Roger Hall's Avatar
Sounds like you will need a very large bench that is bolted to the floor. Maybe you could use a starter motor. You will need to research this, but the speed of a DC motor is controled by the amps available. I can see many ugly posts that begin with OH CRAP in your future though.
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 03-31-2003, 03:46 PM
AFJuvat's Avatar
Good idea, but you are thinking in reverse.
Put it in gear, then spin the hubs where the CV's bolt to.
Easier to do in higher gears.
In 5th, you should be able to spin it with your hand - gives you something a little more substantial to grab onto than the input shaft.
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-31-2003, 04:23 PM
ae1969's Avatar
Hey mother juvat....
Uhmmm I first thought that made sense... so I put an allen key in and spun it with a ratchet.... ....
So I get noise where the Differential section is.....but couldn't that noise be because of the differential spiders are turning and working as one hub goes one way and the other ....u know.
It is a rythmic clicking noise coming from the diff area.... I haven't spun it quick enough to get the grinding, gearing, watchamacallit sound you heard a week ago at the back of the tranny.........
Maybe I'll put a drill on that allen key.... make it spin a little faster...
Old 03-31-2003, 05:14 PM
