O2 sensor check 85- 944
Does anybody know how to check an single wire o2 sensor? mine reads open when cold.?? runs rough when cold also.
Old 04-26-2000, 05:43 AM
Send a message via ICQ to Ptech
Put a volt meter on the wire from the sensor, it should read around 450 MV or .4 - .6 volts
And should vary as you accelerate.
ptech
Old 04-28-2000, 04:08 AM
Thanks for the info, I ordered a new one.
It would read -.5 to .1 and jump around when pulling on the wire.Next problem is the cold start circuit, but I will see what this does after I get the throttle body adj. back somewhere in the ballpark.
Old 04-28-2000, 05:43 AM
