Altitude sensor mounting
My altitude sensor is hanging down below the steering wheel and ziptied to some wiring. From the parts catalog it looks like it is supposed to be mounted alongside the Motronic DME box and may use the same mounting bolts/screws as the DME. Is that right?
I think the previous owner was working in this area and didn't reassemble everything properly.
Car is 1984
Old 12-18-2019, 11:56 AM
yep, you are right it use same screw and holds alongside the ecu
Old 12-18-2019, 12:31 PM
