944 addict
Door/window channel HELP!
I'm rebuilding and replacing my door mechanisms after the paint shop damaged several parts trying to put it back together. A problem that has caused me more headaches is because the rear window channel and brace doesn't seem to be removeable. I've looked for rivets, screws, bolts to no avail and it's making putting the door mechanisms impossible to reinstall. Does anyone have an answer to this?
This is the channel in question, behind the inner do opening cable. Next Page..Sorry for the picture not being oriented correctly. The pic should be rotated right 90 degrees.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Last edited by mytrplseven; 04-10-2020 at 02:16 PM.. |
944 addict
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
curtisr
Are you referring to the rear hatch? If so, is it a question of lining up (or not lining up) the hatch pins with the receivers? If that's the case, you can make adjustments by following these instructions.
1977 924 Guards Red (parted and sold) 1987 924s Alpine White (sold) 1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold) 1987 924s Garnet Red (currently becoming Lowencash II) 1982 928 Silver (sold)
In the Fires of Hell.....
You don't say what car this is for, and your garage only says "NA" and '86 951.
The early cars have the channels welded in place. You have some 8mm bolts at the top and bottom of the channel on later cars that you remove to take them out. The top one is behind the rubber window weatherstripping. The bottom one should be inside of the door, as I remember...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
944 addict
Sorry for being obscure. This Is my '86 951 and there's no channel bolts that I can see. Is it possible that the channel is bolted to a tab on the bottom and hidden behind the trim on the top? I'll put my hands and fingers in there again tomorrow, but I pretty much scoured the bottom for an attachment.
944 addict
I was referring to the driver's door on my '86 951.
Yes, it's behind the rubber on the top. You will not see it until you remove that rubber.
Bottom should be more visible.
Around minute 4, the guy in this video says there is a 7mm on the bottom and a 8mm at the top.
https://www.youtube.com/watch?v=GqfT8ZkXKCI
1984 944 Zermatt Silver 1987 951 Flamingo Metallic |
great video
https://m.youtube.com/watch?v=3k61Ix14BVQ
This helpful video showsthe latch release mechanism insitu and on the bench and how areas can wear over time from use and abuse. I may need to replace my passenger side release if the new trigger and new linkage and lube job don’t do the trick. |
944 addict
Atta boy, Chris. You are the man. Thanks so much for finding that. Now I can put this mess back together. Yeeeha!
And thanks to everyone for their input and help.
