Remove & Reposition rear "944" badge
A previous owner had the car resprayed and whoever reapplied the "944" badge to the rear didn't make much of an attempt to place it in the correct location.
I should probably just leave it as-is, but it does bother me. I'm hoping that I can remove it without damaging the badge itself or the underlying paint. I have some plastic trim removal tools and dental floss. Any other or better ideas?
Is there a recommended adhesive to reapply - and most importantly, is there a known set of measurements to make sure the "944" gets positioned properly?
Thanks!
1984 944 Zermatt Silver
1987 951 Flamingo Metallic
Old 04-27-2020, 07:14 AM
I'm not 100% sure if it matters but you may want to post the year of your car in case there were slight differences over the years like early versus late 944.
Old 04-27-2020, 07:34 AM
GooGone is a good adhesive remover and most auto parts stores sell 3M trim adhesive tape which is what I'd recommend.
Old 04-27-2020, 07:35 AM
Ernie944's Avatar
If you remove it why not get something decent to replace it.I know migth be out off the box .This is my own design. 83-944.
Caraquet,N.B. Canada.
Old 04-27-2020, 08:44 AM
I found a post on Rennlist describing the vertical factory location as one inch above the bend and mid-point of the middle number (4) is just about lined up where the the brake and reverse light lenses meet. This seems right to me. By that metric I'm about 1/2 inch too low and 1" too far to the outside edge.
Old 04-27-2020, 01:41 PM
Seems accurate. This is my 1986.
Old 04-27-2020, 02:31 PM
Thanks a lot for the photo!
Old 04-27-2020, 02:39 PM
9FF 9FF is offline
9FF's Avatar
Source: https://pin.it/4tDVEMc
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 04-27-2020, 04:34 PM
Wow, perfect! I'm going to get my dental floss working on my badge.
Old 04-28-2020, 05:10 AM
