Pike's Avatar
Location: Redmond WA Can anyone help me with my snorkle mod?
I can't get my injectors out!
I was going to take them out because they seemed awfully loose, but they won't unscrew or pull out! Haynes says that they should pull out 'quite easily,' but no such luck. What should I try before I pull really hard?
'77 924 - Metallic Blue - enlarged TB/ intake
'99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer
If it ain't broken, drive it until something is.
Have you spent quality time with your Engine Gnome lately?
Defend Your Joy
Old 04-24-2003, 08:19 PM
Wolf1's Avatar
Chances are; if you pull them out, and the rubber seals are brittle you will destroy the seals. Unless you have some new seals on hand, I wouldn't chance it. Order new seals first -- if you think they are leaking -- then pull them out and clean them. Or......just pull really, really, hard and see what happens.j/k..
75 914 - Undecided.
80 931 - Gone, but not forgotten.
72 914 - old toy- sold.
And a whole bunch of German scrap metal shaped like 924's.
Old enough to know better, and stupid enough to do it anyway!
Old 04-24-2003, 08:46 PM
Pike's Avatar
I don't think they are leaking, but I would bet they need cleaning. Are they suppposed to be really loose? I was really surprised. I will leave them alone for now I guess, with special attention to see if they leak.
Defend Your Joy
Old 04-24-2003, 08:49 PM
Mine are difficult to pull out. What I do is squirt some motor oil on the O-ring that is in the block. Then I pry each one a little at a time with, of course, the fuel rail unbolted from the valve housing and head. The prying tool I use has a split end on it that goes around the injector near its base. It has a curved shaft and is about the size of a medium screwdriver.
Mine wiggle when I unbolt the rail bracket from the valve cover and head. Because they wiggle does not necessarily mean they leak air pressure.
Lawrence
1986 951
2002 SLK32 AMG
1987 328GTS
2011 528i
Old 04-25-2003, 04:38 AM
overkill's Avatar
Send a message via AIM to overkill
Haynes: They pull out quite easy.
Trans: They pull out quite easy,........ with a small crowbar.
{1987}944S - (SOLD).
Old 04-25-2003, 10:48 AM
SidVicious's Avatar
That mirrors my sentiments about Haynes to a T.
Old 04-25-2003, 11:29 AM
overkill's Avatar
You ever see the thread I think Juvat started or maybe SoCal. It was all haynes trans. Funny stuff.
Old 04-25-2003, 11:36 AM
gearhead290's Avatar
Send a message via AIM to gearhead290
Pull harder...they'll come out. Don't forget to vasceline the lil guys up though when you put em back in
95 240sx-track slut w/ too much done to list
87 944 n/a-old "toy" that broke too much
Old 04-25-2003, 12:48 PM
