Location: Redmond WA Can anyone help me with my snorkle mod?
I can't get my injectors out!
I was going to take them out because they seemed awfully loose, but they won't unscrew or pull out! Haynes says that they should pull out 'quite easily,' but no such luck. What should I try before I pull really hard?
'77 924 - Metallic Blue - enlarged TB/ intake '99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer If it ain't broken, drive it until something is. Have you spent quality time with your Engine Gnome lately? Defend Your Joy |
Chances are; if you pull them out, and the rubber seals are brittle you will destroy the seals. Unless you have some new seals on hand, I wouldn't chance it. Order new seals first -- if you think they are leaking -- then pull them out and clean them. Or......just pull really, really, hard and see what happens.j/k..
75 914 - Undecided. 80 931 - Gone, but not forgotten. 72 914 - old toy- sold. And a whole bunch of German scrap metal shaped like 924's. Old enough to know better, and stupid enough to do it anyway! |
I don't think they are leaking, but I would bet they need cleaning. Are they suppposed to be really loose? I was really surprised. I will leave them alone for now I guess, with special attention to see if they leak.
'77 924 - Metallic Blue - enlarged TB/ intake '99 Specialized HardRock - Blue/Silver - Jett C Shocks - Cat Eye Velo computer If it ain't broken, drive it until something is. Have you spent quality time with your Engine Gnome lately? Defend Your Joy Last edited by Pike; 04-24-2003 at 07:53 PM.. |
Mine are difficult to pull out. What I do is squirt some motor oil on the O-ring that is in the block. Then I pry each one a little at a time with, of course, the fuel rail unbolted from the valve housing and head. The prying tool I use has a split end on it that goes around the injector near its base. It has a curved shaft and is about the size of a medium screwdriver.
Mine wiggle when I unbolt the rail bracket from the valve cover and head. Because they wiggle does not necessarily mean they leak air pressure.
Lawrence 1986 951 2002 SLK32 AMG 1987 328GTS 2011 528i |
Haynes: They pull out quite easy.
Trans: They pull out quite easy,........ with a small crowbar.
{1987}944S - (SOLD). |
89 951 |
You ever see the thread I think Juvat started or maybe SoCal. It was all haynes trans. Funny stuff.
Pull harder...they'll come out. Don't forget to vasceline the lil guys up though when you put em back in
95 240sx-track slut w/ too much done to list 87 944 n/a-old "toy" that broke too much |
