universeman's Avatar
968 transaxle noise level - normal
Hey all,
If cruising at 70mph with radio off and windows/roof closed, RPM steady, can you hear your transaxle? If so what does it sound like?
Jason
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 12-15-2020, 06:37 AM
Ernie944's Avatar
Originally Posted by universeman View Post
Hey all,
Jason
You should'nt hear any noise from the 968 transaxle,maybe a buzing sound but not a loud one,had a 968 for over ten years never heard any loud noise .Your sure it's not something else you are hearing ,like a wheel bearing or half shaft.
Caraquet,N.B. Canada.
Old 12-15-2020, 06:53 AM
Well I hear something. Guess I need to tear into more stuff! 🙃
Old 12-15-2020, 06:34 PM
pinion bearing?
Seems like they all have it over shimed from the factory. need to replace bearings and proper set up
Old 12-15-2020, 08:15 PM
the side cover comes off quite easily.
Old 12-16-2020, 01:16 PM
Kessel run in 12 parsecs!
Fast Freddy 944's Avatar
Hey all,
Jason
My turbo's transaxel makes all kinds of growling rah-rah noises. I put in some high shock drag racer tranny oil in my ride, reccomended by a local porsche shop and its quieted it down. When your tranny is making a noise in its transaxel, its going to be your sincromesh going out. They wear out and they make some really nice noises, the other thing is check your tranny oil level, and lastly the old ring and pinion gear being worn out...
Getting old sucks, bring back the good old days, this new stuff is for the birds..
Old 12-18-2020, 05:50 PM
i bought a wired 'chassis ear' kit years ago which is quite helpful in pinpointing issues. 'bout a hundred bucks
Old 12-20-2020, 04:21 AM
commdiver's Avatar
Pile be the pinion bearing in transaxle or the diff bearings but if it’s resonating inside can a lot put your hand On the rear of the tunnel it could be the torque tube bearings going out there’s 4 in there and 30 years old a lot of these torque tubes bearings are getting noisy on these 944/968 cars
Old 12-30-2020, 05:23 AM
