Yan Yan is offline
What is this part? (really ugly picture)
Hi!
I did my oil change today and I noticed this REALLY worn bushing. My powersteering rack is leaking BADLY so I guess it doesn't help.
- What part is it exactly?
- How much does it approximatively cost?
- Is it dangerous to run with this problem (low-high speed)?
I can hear a "clunk" when turning at low speed in my driveway.
Thanks for you help!
.: My turboed 944 - Videos | Pictures | Specs [...] :.
One ride and you'll understand why most rocket scientists are german.
Old 04-29-2003, 03:16 PM
Non Compos Mentis
That's your front sway bar. No danger, just goofy handling, and yes, power steering fluid eats rubber.
Old 04-29-2003, 03:19 PM
85944na's Avatar
Send a message via ICQ to 85944na Send a message via AIM to 85944na
pretty easy and cheap to replace, get a new one.
PORSCHE: NOTHING EVEN COMES CLOSE
Early 85 G-red 944na, S2 transmission, Ice Shark grounds, Cibie E-Code lights, turbo rear valance, 924S gauges, Turbo S full power seats, "Porsche" door handles, Enkei Wheels.
95 Infiniti G20 dark red metallic-for sale soon
87 BMW 325ic Bronzit, stock(for now)
Old 04-29-2003, 03:37 PM
last year I had the clip (bracket) snap on me so I changed all the sway bar bushings and both hanger clips. (scary, a few weeks before the steering shaft broke.)
then I could see the steering rack was on it's way out and it's bushings...the tie rod assemblies...ball joints...all the control arm bushings...struts...wheel bearings...and that was just the front…and I knew I needed at least 1 rear wheel bearing, so.....
then new 17's all around and HEY, this thing really does handle like a sports car!
Tom
Early '85 944
Old 04-29-2003, 03:53 PM
DennisR_944's Avatar
The part (bushing) is around $7 and it takes about 20 minutes to change.
Dennis Russell
Indianapolis, IN USA
1987 944 n/a
RLM #020131-3340
Old 05-03-2003, 06:46 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Porsche Crest
Yan, Change all the sway bar bushings not just the one! Sman
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 05-03-2003, 08:09 AM
944play's Avatar
can worn sway bar bushings be the reson for the clunk at slow speeds??
`83 944
GTS Pearl BLue (Sold)
`86 944
with Momo accents
Old 05-03-2003, 09:43 AM
Send a message via AIM to XJOSHX Send a message via Yahoo to XJOSHX
yes because I had that same exact problem happen to me on my last 944. It also made clunks over bumps too.
1983 944 - Project Time!
1986 944T (Stolen)
1987 944 N/A (Sold)
1984 944 N/A (Sold)
1986 944 N/A (Sold)
Old 05-03-2003, 09:55 AM
speedy007's Avatar
not many of you have experienced this, but the rubber bushing comes in 3? different sizes.
larger bars require larger bushings, you can install 1 size over but i couldnt make it go 2 sizes and had to buy the proper size bush.
just a thought...
88 944 bastard
Old 05-03-2003, 11:07 AM
Yan Yan is offline
Thanks everybody for your help! Which bushing is it? The inner or the outer? The inner I imagine?
Is the outer as easy to change as the inner if I change both at the same time?
Old 05-13-2003, 04:59 AM
AFJuvat's Avatar
That is the inner bushing
It isn't hard to replace them all (innter and outer) at the same time - but do measure the diameter of your sway bar - they came in 3 different sizes depending on option and year.
Soapy water helps get the bushings in their holders easily
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-13-2003, 05:11 AM
Take a caliper and measure the diameter of the sway bar (stock is like 20.5mm) to make sure you get the correct bushing.
Before you replace the bushing, clean the undercarriage and fix the power steering leak. A common leak point is where the hosed connect to the bottom of the reservior. Just cut the hoses back a little and then reattach.
spray the bushing with some silicone lubricant, makes it easier to slide onto the sway bar.
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 05-13-2003, 10:25 AM
