Send a message via AIM to TheCooler
Clank Clank Clank
Alright well today my car wouldnt start cuz the battery died so I hadda pop start it ...btw how bad is that for your car? Anyways I get it going and drive around for a while without my music on so my battery can charge. All I hear when im shifting is clank 2nd gear clank 3rd gear clank 4th and so on. I try it again but it doesnt happen. Then im driving along and it clanks again. I drop it down into 3rd ..no clank then i upshift to 4th then clank. I stop the car and i clank into 2nd then no clank into 3rd then i downshift to 2nd then a clank..alright ill stop. Anyways i get in the garage and turn it off. I press on the clutch and move the shifter around 1st gear clank 2nd gear clank 3th gear clank reverse clank....what is it??? Do i need a clutch job? Or a tranny job or is this normal. It has been doing this on and off since ive had it.
-2002.5 GTI VR6 24V 6SPD
-Kalahari Beige 89 Porsche 944S2
-87 VW GTI 1.8 16v
-2007 Ford PIMP(free)star ...company car....
-1999.5 Jetta VR6
Old 05-14-2003, 12:16 PM
AFJuvat's Avatar
your clutch is on its way out
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 05-15-2003, 12:41 AM
MrPants's Avatar
when mine was doing that the mechanic said it was cause the "clutch coupler" is going. i think its a rubber centered disk issue or something.
replaced the clutch:noise is gone
84 944 Non Alcoholic
Old 05-15-2003, 03:28 AM
SoCal Driver's Avatar
Always "pop" start your car in third or fouth gear. Never in first or reverse unless absolutly necessary.
Replace the clutch disc with a spring center unit.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 05-15-2003, 10:09 AM
Nabeel's Avatar
Send a message via AIM to Nabeel
What's a 'pop' start? Starting the car while its rolling?
'85.5 944
Kalahari Beige/Brown
5-speed
76K miles
color-matched fuchs
SOLD
Old 05-15-2003, 11:57 AM
Send a message via ICQ to interglossa
Your rubber center on the clutch disc has shattered or separated. It's what happened to mine. Sadly the wear surface had tons of material left.
I agree, get a spring centered disc. It's a bit rougher, but more reliable.
And don't forget to resurface the flywheel... they tend to chatter otherwise.
My '83 Sets me free!
Old 05-15-2003, 12:56 PM
Shepper's Avatar
Check your axles first before you go ripping into your clutch.
Might as well, they are right there in the open and they will clank when they're going out too.
Clank up front: clutch
Clank in the rear: Axles, maybe transaxle.
'83 944 N/A
www.ColoradoMusicians.com
Old 05-15-2003, 03:48 PM
mmm... I thought so, Ill check my CVs tomorrow and see if its them because to car shifts smooth except for the clank. I guess ill be calling tony unless its the CVs.
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-16-2003, 06:19 AM
It's not the CV joints. It's the clutch. Just wishful thinking.
Old 05-17-2003, 10:30 AM
*tear* it is the clutch. There goes my next paycheck ..lol
-87 VW GTI 1.8 16v
-1999.5 Jetta VR6
Old 05-17-2003, 02:44 PM
*IF* your throw out bearing is decent as well as the pressure plate and no leaking flywheel seal you can get away with just the disc and a weekend full of work.
*IF* the rivits on the clutch disc have gouged the flywheel and pressure plate then yes it's time to replace them.
Old 05-17-2003, 08:38 PM
