Toofah King Bad
Adjustable Cam Gear
Anyone got a recommendation? I already looked at the Lind$ey version.
TIA rasta
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
That Guy
May want to contact Dave at CEP, not sure what his costs. He makes some very nice custom parts.. i have a few on my car
![]() Custom Engineered Performance CEP - porsche 944 dry sump
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
porscha
porsche 944 1986 NA 8 valves 230k Kilometers on the clock weltmeister chip and coil springs , KYB gr-2 shocks all around , weltmeister throttle cam ! REbuilt head and all new sealed Upper motor ! fresh Canada , Quebec |
Jeff AKA - FT/Factorytuned on Rennlist makes some pretty sweet kit. i picked up a complete set secondhand unused.
944/944 Turbo Adjustable Cam Gears, Lightweight Gear/Pulley Sets GROUP BUY - Page 12 - Rennlist Discussion Forums ![]()
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels Last edited by J1NX3D; 02-09-2011 at 10:47 PM.. |
Thanks for the kind words! Glad you were able to get a kit...
Man that blue is killer! ![]() Jeff AKA - FT/Factorytuned |
Just saw this. No problem
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Is there a documented performance increase on the 2.5L from using an adjustable cam gear?
If so, you might be able to use an offset key to set it to whatever the documentation states for max power and not have a need to adjust it. Just curious, good luck on the search.
Stefan Portland, OR 1979 Porsche 924 Carrera GTS (clone-ish) 1988 Porsche 944 Turbo S (Silver Rose) |
This is what I bought: CAM Gear 4 Deg +/- Adjustable Balance Shaft Drive Gear Accessory Master Pulley Alternator Pulley Power Steering Pulley And Hub Balance Shaft Gears Lightened and Balanced w/ Thrust Washers Short of using the adjustable camgear I should be claiming back a small % of hp from the weight savings. somewhere in that thread I linked is this quote by FT: Quote:
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels Last edited by J1NX3D; 10-19-2011 at 06:17 PM.. |
Awesome i want those.... gimme gimme gimme
who else does stuff like this ???? |
I reckon express interest in that Rennlist thread and bump it back to the first page so it attracts more potential buyers. FT usually advises when he can or can't make a batch but you'll see in the last few pages he's bumping the thread himself for interest before he does a run.
noice.........................
Wow, that's about five years old!(the "quoted info) These parts have met with major refinement and are now in GEN7.. More than 3.5 lbs weight savings. These kits have seen many dynos many times, I'm sure. Best thing to do is grab a baseline set of pulls then a new set after installation. You will see power recovered.
The original design intent was to reclaim the Balance Shaft Setup. Porsche says 5bhp cost to run them. You should see every bit of this back on the NA. Some have claimed 13hp recover at the wheels on the 4451 motor. But I have never seen charts. AND these were generally pure race guys. I have seen 11 from my day driver 951 on a gen3 set. But generally refinement is found on the NA and low end torque is improved. PCA sanctioned legal for Club racing as of 09' and I have been told that low end torque is the change on the NA in the PCA/NASA Cup circuit. Is a good reference as the PCA Cup cars are for the most part "program motors", they have to stay stock for the most part. I really have let that GB on rennlist die out, as the one fellow said. Most guys know how to get in touch with me at this point as I've been offering these for about 6 years now. Check out the website, I'm making some gorgeous turbo parts for the 26/6 and 26/8 turbochargers as well as bottom-end studs, etc.. You can find specs on the gears and pulleys as well. Please feel free to ask any questions but refrain from posting question with regard to $$$, etc.. As I am not a sponsor of this board and do not want to get into trouble. Thanks again for the interest. Jeff AKA- FT/Factorytuned |
Dog-faced pony soldier
Pimpin' I like.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
ooooooooooooooooo, i know where my next pay check is going
All Spooled Up
The issue that I have with current adjustable cam pulleys is that the adjustment can only tune the cam to a particular engine rpm. And with that you actually take a hit, in terms of performance, at the rpms that it is NOT tuned to. Unless the car is used strictly for racing, the losses outweigh the gains, in my opinion. The stock cam timing is already the best compromise for street driving.
Enter the adaptive (self-adjusting) camshaft pulley. It dynamically changes the cam timing, depending on what rpm it is running at at any given instant, on-the-fly. As far as I know, this device is now merely a figment of my imagination. So I am going to have to consider this post a call for someone to "invent" it. If you could make something like this work, you could make BIG money (and not just on p-cars). In having an engineering background, I understand why it would not be an easy thing to accomplish, especially if trying to do it via purely mechanical means, packed inside of the pulley itself, considering the forces that the shaft undergoes. It wouldn't be as simple as the centrifugal spark timing advance in a distributor, but would operate under the same principle. For it to work, you would somehow have to harness some of those forces to work FOR you, instead of against you. If that simply isn't feasible (but never say never), electrical or (now we're getting complicated) hydraulic actuation could be a possible route to making it work. Could I be on to something here? Or is my imagination running away with me again. |
IIRC Once upon a time there was something called a "franco gear" that did dynamic cam timing via weights I believe. I believe it was only for the 924 though and long since gone from the market. Never actually seen one in person but there was lots of discussion over on 924.org at one point
I do have an adjustable cam gear on my toofah. $75 from ebay. Works fine. No idea what brand tho (IPC? DPC? something like that). If you want to know, PM to LMK and I can go look... |
All Spooled Up
I do appreciate the input, but I don't think that the problem is in "controlling" the advance/retard, but rather in making it move under the high load that the the valve train presents to the pulley. Opening exhaust valves when under pressure probably takes quite a bit of force, which has to be fed through the pulley.
Continuously variable would be the ideal goal, but a design in which there are say, 3 different possible positions (for low, mid, and high rpm) would surely be easier to make happen, and still be pretty effective. Even that would be no easy task, but I REFUSE to believe that it is outside the realm of possibility. I think that a 3-position (only need 2 actual steps) mechanical/centrifugal force based setup that is completely contained within the pulley is the obvious place to start. If that can be made to work, continuously variable might be a possible goal for generation 2. |
924 franco discussion: 924Board.org :: View topic - Franco Gear
http://www.selendesigntech.com/xFranco.aspx ![]() with my cam gear, I was going to leave it at the stock timing setting. i was happy enough with the balance and weight loss of the item than mess with the timing.
Variable Valve Timing-even my daughters Mini First 1.4 has it(its basically a Peugeot motor),and after 2000 miles the servo that controls it failed,so she had to drive home in failsafe mode.
1986 924S bought new. Now used for AutoX and street. Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway Hyundai Ioniq hybrid daily driver Vindicator Vulcan V8 spyder, street legal sports racing car (300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs |
