944freak's Avatar
Send a message via Yahoo to 944freak
Question Compression Test
How should I do a compression test on a 86 951? My dad is taking the car for a test drive for me and I thought maybe he should do a compression test before I buy it. Can somebody give me some step by step instructions I can send to my dad? I did a search but didn't find exact procedure. Thanks.
1983 944
Old 05-24-2003, 08:19 PM
turbohead7's Avatar
Post Compression Test Procedure
Here you go dude:
1: Make sure car has a healthy battery, and engine is warmed up.
2: Unplug fuel pump fuse and run car until it stalls, this will clear the fuel rail, leave fuse out for remainder of test
3: Block throttle plate wide open with a screwdriver.
4: Remove the plugs and air cleaner (preferably)
5: Insert compression guage into corresponding cylinder*
6: Crank engine over until guage shows no further rise, usually 4 or 5 compression strokes.
7: Record readings as you go for comparison, the lowest cylinder shouldn't read 10-15% below the highest cylinder.
*Make absolutely sure that the compression guage fitting is the same length as the spark plug threads!
Even though I drove a GT2, I still love my 944.
Old 05-25-2003, 11:05 PM
Verruckt's Avatar
You may also want to have a battery charger hooked up between readings. The starter will turn slower and slower with each crank. My Interstate battery was gasping for breath by the time I got to my final pull! ;_0
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 05-25-2003, 11:51 PM
