Emnyama944's Avatar
968 Variocam issues
Hi all, I'm rebuilding an engine from a burnt out 968 to put in my 944 Turbo and I am about 90% done but I think I'm having trouble with the timing chain tensioner when I'm trying to set the timing, I was thinking I might try replacing the variocam tensioner with one from a 944S2, does anyone know if they swap out directly or are there other options?
any assistance would be appreciated.
Thanks,
Old 06-05-2022, 08:06 PM
Probably not a good idea. Do you have the factory workshop manual for the 968. IIRC, you have to pressurize the variocam tensioner with compressed air while setting the timing.
Good luck, George Beuselinck
Old 06-06-2022, 05:23 AM
I would check the Porsche parts PET and compare the part numbers.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP
Old 06-06-2022, 07:26 AM
You'd at least have to put in the S2 cams and cam cover, assuming the tensioner fit.
You can reasonably set the cam timing by matching where it was set before and it'll run fine, or check the exhaust cam timing with a dial indicator and don't freak out about the intake cam timing. It shifts as the pads and chain wear anyway.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 06-06-2022, 07:36 AM
Emnyama944's Avatar
Thanks for the replies, I appreciate the advice. I do have the workshop manual, or at least a downloaded copy of it and I did try to pressurize the tensioner, I'm going to have another try this weekend after reassembling the head just to make sure I got it all together correctly.
Old 06-10-2022, 11:45 AM
