Can We See Some Engine Bays?
I'm looking for some motivation to clean up my engine bay. Mostly just to clean things, but maybe there's some fun ideas out there to remove things, tidy things up, etc.
Any chance we could start a thread of people showing off engine bays? All are welcome - Dirty, Cluttered, Clean and Stock, Modified, Race cars, etc. |
I have an '86 944 that's been 968 swapped so when I later had it painted I took the opportunity to swap to a 968 washer reservoir that sits in the front right guard behind the inner guard liner. it's not compatible with 944 bonnet struts so my fabricator made a workaround for it and i plan to change to the 968 bonnet hinges and gas struts to clear the filler neck.
I had my engine cover and intake colour coded to match my wheels. My brake fluid reservoir was changed, the coolant reservoir was new too but I've been chasing cooling problems since the 968 swap and overheating is apparently enough to brown the reservoirs plastic. I have an RS Barn heat shield on the exhaust manifold and a bespoke strut brace. I have also picked up a 924 Turbo headlight motor so I can have motor on each headlight and remove the cross bar but I'm not 100% if I want to do that yet, but it would help put in a larger diameter pipe from the S2 airbox to the 968 MAF. The current pipe steps down in diameter and has a cut out for the cross bar. i'll share a few photos shortly.
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Here's a good resource, if you're hunting for pictures: https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/812643-show-us-your-engine.html
Since that thread has been dead for about as long as the type 944's production run, I'm all for some new pics in a new thread. Here's my '84's bay: ![]() ![]() ![]() Two years ago: ![]() ![]() ![]() Still want to get some accessories and other bits re-plated, but it's getting there!
'84 944 5MT / '89 ANDIAL 951 / '92 MX-3 GS 5MT Projects: '82 928 5MT / '85 944 5MT / '92 740 Turbo Wagon |
There you go AJT944...my ex early 83 -944 & then my ex 93 -968
Caraquet,N.B. Canada. |
These are awesome! Thanks for the responses - Let's keep this going!
The newest of the noobs!
Here’s my 1989 turbo. Was cleaner when I bought it 8 years ago!
here's mine
Ernie944 how did you do the red parts in your engine bay. I like them.
1988 924S 5 Speed |
Few Pictures. ^_^
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*. 1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother 1983 944NA Gave to my Dad for being Awesome. |
My '85 944 with GM V6 swapped in it...alarmingly fast.
The bundle of wires is for the headlights/fogs/etc. ![]() |
Thanks ernie944. I think I will give it a try.
1988 924S 5 Speed |
What you should do is make a test on a piece of steel or alluminium,take your time & like said,apply coat very ligthly until you get the desire hue,take care & have fun
![]() Not immaculate, but was much much worse when I got the car. Shows what you can do with a little elbow grease. Last time I had the intake off I painted it.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP |
Thanks ernie944. Will do.
1988 924S 5 Speed |
Here are some engine bays pics from my files , those cars belong to both Pelican & Rennlist members..Enjoy
Best, John |
https://944hybrids.forumotion.com/t3804-lz9-3-9l-v6-in-1985-944-gm-60-degree-v6-swapped |
