Can We See Some Engine Bays?
I'm looking for some motivation to clean up my engine bay. Mostly just to clean things, but maybe there's some fun ideas out there to remove things, tidy things up, etc.
Any chance we could start a thread of people showing off engine bays? All are welcome - Dirty, Cluttered, Clean and Stock, Modified, Race cars, etc.
Old 08-22-2022, 01:04 PM
J1NX3D's Avatar
I have an '86 944 that's been 968 swapped so when I later had it painted I took the opportunity to swap to a 968 washer reservoir that sits in the front right guard behind the inner guard liner. it's not compatible with 944 bonnet struts so my fabricator made a workaround for it and i plan to change to the 968 bonnet hinges and gas struts to clear the filler neck.
I had my engine cover and intake colour coded to match my wheels. My brake fluid reservoir was changed, the coolant reservoir was new too but I've been chasing cooling problems since the 968 swap and overheating is apparently enough to brown the reservoirs plastic. I have an RS Barn heat shield on the exhaust manifold and a bespoke strut brace.
I have also picked up a 924 Turbo headlight motor so I can have motor on each headlight and remove the cross bar but I'm not 100% if I want to do that yet, but it would help put in a larger diameter pipe from the S2 airbox to the 968 MAF. The current pipe steps down in diameter and has a cut out for the cross bar.
i'll share a few photos shortly.
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 08-22-2022, 03:18 PM
Here's a good resource, if you're hunting for pictures: https://forums.pelicanparts.com/porsche-924-944-968-technical-forum/812643-show-us-your-engine.html
Since that thread has been dead for about as long as the type 944's production run, I'm all for some new pics in a new thread. Here's my '84's bay:
Two years ago:
Still want to get some accessories and other bits re-plated, but it's getting there!
'84 944 5MT / '89 ANDIAL 951 / '92 MX-3 GS 5MT
Projects: '82 928 5MT / '85 944 5MT / '92 740 Turbo Wagon
Old 08-23-2022, 05:20 AM
Ernie944's Avatar
There you go AJT944...my ex early 83 -944 & then my ex 93 -968
-------93-968 engin bay
Patient & little details are the key ,so take your time & have fun.
Caraquet,N.B. Canada.
Old 08-23-2022, 08:29 AM
These are awesome! Thanks for the responses - Let's keep this going!
Old 08-23-2022, 09:15 AM
The newest of the noobs!
grendiers's Avatar
Here’s my 1989 turbo. Was cleaner when I bought it 8 years ago!
Old 08-23-2022, 09:52 AM
J1NX3D's Avatar
here's mine
- 6 spd/LSD
Old 08-23-2022, 11:31 AM
Ernie944 how did you do the red parts in your engine bay. I like them.
1988 924S 5 Speed
Old 08-23-2022, 11:43 AM
Ernie944's Avatar
I also use that paint on the 968 fan shroud & rad cap....it is call Dupli-Color metal cast it's a Anodized paint , when apply properly will last a long time --0n metal--aluminium--& even Chrome.Parts should be exempt of rust or dirt so you need to clean then well .Apply a first coat very ligthly & keep building it up until you reach the desire hue.NB this paint is also heat & grease proof.Sending you some pics .
Old 08-23-2022, 02:02 PM
Few Pictures. ^_^
1982 924 *Audi V8 Swap In Progress*1985.5 944 NA *3.0L 16V swapped* 1987 944 Turbo *3.0l 8V*.
1987 944 NA 1991 944S2 2001 VW Passat, *Built 1.8T* 1985.5 944NA Sold to younger brother
1983 944NA Gave to my Dad for being Awesome.
Old 08-23-2022, 09:53 PM
My '85 944 with GM V6 swapped in it...alarmingly fast.
The bundle of wires is for the headlights/fogs/etc.
Old 08-24-2022, 07:13 AM
Thanks ernie944. I think I will give it a try.
1988 924S 5 Speed
Old 08-24-2022, 08:08 AM
Ernie944's Avatar
What you should do is make a test on a piece of steel or alluminium,take your time & like said,apply coat very ligthly until you get the desire hue,take care & have fun.
Old 08-24-2022, 03:10 PM
Not immaculate, but was much much worse when I got the car. Shows what you can do with a little elbow grease. Last time I had the intake off I painted it.
Tyler from Wisconsin, 1989 944 S2 on Megasquirt PNP
Old 08-25-2022, 05:24 AM
Thanks ernie944. Will do.
1988 924S 5 Speed
Old 08-25-2022, 07:41 AM
Ernie944's Avatar
Here are some engine bays pics from my files , those cars belong to both Pelican & Rennlist members..Enjoy
Old 08-25-2022, 04:22 PM
What's that bracket you have holding the air filter up? Looks nice and clean/simple.
Old 08-26-2022, 02:14 PM
Ernie944's Avatar
....Thank's AJT944....Part of my job at one time was frabricator -welder,,,so I did all the parts out of alluminium myself to attache the K&N throtle body,I also frabricated and air intake with a screen ...see last pic....where the OE one came in so no dirt or water will come in.sending you pics so maybe you can figure out where all the attachements were located ...
In the first pic would will see a flat bar ...on the left side of the main braket...that was to hold the rad hose up once the OE air boxe was remove.
....Sorry it's hard for me to explain how everthing was done ,cause first it's was done a long time ago & I didn't take any measurments at that time
Old 08-26-2022, 05:49 PM
V2, I was unaware of this one. Is there a thread on it anyplace I could read? I’ve always thought that a V6 would make way more sense than a V8.
Best, John
Old 08-27-2022, 05:09 AM
Best, John
Most of the relevant info is here, but it's not a build thread:
https://944hybrids.forumotion.com/t3804-lz9-3-9l-v6-in-1985-944-gm-60-degree-v6-swapped
Old 08-27-2022, 05:34 AM
