Windshield washer system will not prime
Hello all
After replacing the entire windshield washer system components on my 84 944 I cannot get the system to prime. Everything is new including 2 different new pumps. Everything new from pickup screen to hood nozzles. Everything is installed properly. Any fixes? |
Pull the hose off the pickup tube, take a spray bottle filled with water, hold it against the hose end and pump the hoses full of water all the way to the t-fitting if you can. Re-connect the hose and try it.
I should add that I have clear hose from the pickup to the pump to the t-fitting as the system is pretty finicky, and mine drains back even after replacing everything. The check valves do not work perfectly. The clear tube lets me see if I have to get it primed again before taking her out.
Early '85 Last edited by originalowner; 05-21-2023 at 09:46 AM.. |
