S2, humming noise from back end.
The other day I'd been cruising down the interstate at 80mph, and pulled off at an exit. I was then merging into the traffic, and doing about 30 in second gear, when I heard a loud humming noise from the back end. It went away after 10s or so and I couldn't reproduce it. No other symptoms really, everything seems fine.
Any ideas folks? A wheel bearing springs to mind, or transmission (please god no!) problem!
Thanks,
Mark
Old 06-16-2003, 12:00 PM
fast924S's Avatar
Send a message via AIM to fast924S
Hey Mark, I would check to make sure you have the right amount of tranny fluid, if there isnt enought those trannies will humm, Also it could be a wheel bearing, but I would worry about it too much if it onyly happened for 10sec if it comes back and last then check it out other then that just keep an eye on things back there
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 06-16-2003, 02:29 PM
SoCal Driver's Avatar
The fuel pumps sometimes cavatate (catch a little air) and make a humming noise.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-16-2003, 04:53 PM
Thanks you guys,
Will check the transmission fluid anyway this weekend, although what SoCalDriver said makes sense as I was really low on fuel at the time and had just taken a long, sweeping bend really quick, so maybe the fuel pump ran on air for a few seconds.
Mark
Old 06-16-2003, 05:05 PM
Don't run the fuel pump dry very often. The fuel actually "lubes" the pump -- the armature is immersed in it.
Think of the 747 center fuel tank effect.
Old 06-16-2003, 05:13 PM
Yeah, now its happened once I'll try not to run it so low.
Glad its not the gearbox anyway (hopefully) !
Mark
Old 06-16-2003, 05:25 PM
I have a question about cavitation. I have that same humming noise from the fuel pump, how could it be sucking in air with a full tank? I thought at first it was the pump itself, but that was an expensive dead end
Old 07-01-2003, 11:27 PM
