Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
Wink Valve spring specifications
I have been searching and looking for information to be able to check out my valve springs, and have found nothing so far - Porsche WSM or Clarke's or every other place.
Turbo Springs - 86
To be able to check them out I seem to need the installed height and the tension at that spot - or a specific spring tension/weight at a certain height of the spring -
Any information will surely appreciated
Thanks, Ed.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-27-2009, 08:32 PM
Redline Racer
HondaDustR's Avatar
Does this help?
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-27-2009, 08:38 PM
Garage Helper
Yes that is correct - but what is the measured valve spring tension at that spot (in nM.) ??? - Need to know if a spring is weak or worn out so as to know if it's good or toss it out.
Old 10-27-2009, 08:45 PM
Redline Racer
HondaDustR's Avatar
I've never seen any pressure specs anywhere in the service manual. I guess the only option there is to get a new one and measure it.
Oh, wait. Here's something.
VALVE SPRINGS at LINDSEY RACING - Your Porsche Performance Parts Center
Old 10-27-2009, 10:31 PM
Garage Helper
Yeah that made my whole day... Wonder why it's not in the Work shop manual or even other places - Oh well it was at LR to be found. Thus saving a much longer search .
Thanks HondaDustR
Old 10-28-2009, 12:10 AM
Garage Helper
OK - I finally found the information for the 951 Valve Springs.
Intake: At installed height 40mm+.5mm and 130#Seat Pressure.
Exhaust: At installed height 41mm+.5mm and 130#Seat Pressure.
Another spot found that both Intake and Exhaust were 41mm +.5 or -.5 at 130# Seat Pressure...
Lindsey makes a Racing Valve Spring at 140#seat Press. etc.
Old 11-19-2009, 08:53 PM
Amatuer Hour Specialist
Wellwood's Avatar
Anyone know what the seat pressure is for the S and S2 valve springs?
Old 12-24-2023, 05:24 PM
