Timing problem ?
I have a 81 924 turbo and it will start and run ok sitting still but when you try to drive it, it will skip and backfire around 4000 rpm .
I have tried to set the timing by disconnecting the wire to the ignition control ( per the book)but moving the distributor doesn’t seem to have any effect . Any suggestions would be greatly appreciated Thanks |
